Question about Panasonic PV-V4522 VHS VCR
Missing remote for panasonic vcr pv-v4522 and eject switch is broken off.....does the remote for this vcr have an eject button?
  • Panasonic Master
  • 5,391 Answers
Is the eject switch one of those plastic type that pushes against a push to make switch (see image below).
If it is you can melt the plastic with a soldering iron so it engages again.
Posted on Feb 09, 2010
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
No puedo programar mi videograbadora para grabar de la tele
tal vez pueda obtener el manual de usuario en este portal : www.retrevo.com es gratis
Apr 09, 2010 | Panasonic PV-V4522 VHS VCR
How locate video heads on panasonic pv v4522
The video heads are a large silver cylinder inside the machine.
I will warn you against using a cloth or anything to clean then as they have a small gap on them and if any dust gets in there it could make the problem a lot worse.
Your best bet is to search google or some where for a video head cleaning tape, they should be fairly cheap these days.
If that doesn't make much improvement then unfortunatly the head is probably going faulty which would need to be replaced by a audio visual engineer.
Regards
Mike
Mar 21, 2010 | Panasonic PV-V4522 VHS VCR
Auto tracking makes no differance.pic.covered by sound bars,black border at top of tape.vcr had stood for 3 months ununsed.on inital play,snapped tape,removed cover to extract tape. new tape kept ejecting...
Sounds like the guideposts need realignment to center the tracking or something got bent in the tape jam removal, check the tape path!. Also could try a take apart cleaning of the head with a piece of paper and some alcohol.
Mar 13, 2010 | Panasonic PV-V4522 VHS VCR
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Panasonic PV-V4522 VHS VCR Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
