Question about Autodesk AutoCAD 2006
I need instructions for autocad mechanical desktop power pack any ideas?
  • rockarafa Feb 26, 2010
    what is the serial no.of auto cade
I need to Get the authorization code for this software that my wife got for me in 2002? It's autocad LT 2002 serial #341-88732540. Key#HQZ3U6. Any help would be appreciated. I've tried registering it...
Autodesk AutoCad 2000 serial: 112-11111111
cdkey: 5X8NUG
Autodesk AutoCad 2000 Educational serial: 111-11111111
cdkey: GX8NUG
auth: FFD54A5A
Autodesk AutoCad 2002 Serial #: 400-12345678
cd-key : T4ED6P
Autodesk AutoCad Data Exchange 2000i 400-12345678
Autodesk AutoCAD Land Development Desktop Release 2i s/n: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2000 serial: 110-98539662
cdkey: 2ZC3DJ
Autodesk AutoCAD LT 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2002 s/n : 400-12345678
cd-key : T4ED6P
Autodesk AutoCAD Map 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2000 s/n: 110-98539662
cd-key: 2ZC3DJ
AuthCode: 08BB785
Autodesk CAD Overlay 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2002 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Civil Design Release 2i serial: 400-12345678
cd-key: T4ED6P
Auth : no requiere
Autodesk Civil Design 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Land Development Desktop Rel. 2 Serial #: 400-12345678
CD-KEY : T4ED6P
Auth : no requiere
Autodesk Land Desktop 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk LightScape name: EzD
company: PWA
s/n: 700-15158000
code: 6A147AF9
Jan 31, 2015 | Autodesk AutoCAD LT 2002...
When save as autocad not responding
Are current with Updates and Service Packs?
Have you tried to PURGE and AUDIT the drawing?
If none of those work, try checking in with the AutoCAD Community for additional visibility.
Philip
AutodeskCare' Community Manager
TW ' PI ' YT ' BLOG
Oct 09, 2012 | Autodesk AutoCAD 2010
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
Unable to load autocad 97 on windows vista
I don't believe Autocad will work at all on Windows Vista.
The only other solution I can think of is to download Virtual Box from http://www.virtualbox.org/
You will need to have an XP cd to install, and basically you will be installing an XP virtual machine, at which time you can then install Autocad 97 onto that virtual machine.
Hope this helps!
Jul 19, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
I have a .dwg file that cause AutoCad 2009 to crash when I attempt to open it. I think that the problem is a missing or 'orphaned' X Ref, but I can't open the file to 'unload' the X Ref. What can I do to...
Thanks for your response.
To fix the problem I redrew the componenet and deleted the offending file. I found that I could open the file with AutoCad LT but not AutoCad 2009 Mechanical.
Best regards
Trebleblank
Nov 06, 2008 | Computers & Internet
How to Autocad LT 97 install to VISTA PC
I have autocad 97 and want to install it on windows 7 can you help please
horriel
Jul 19, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Autodesk AutoCAD 2006 Logo
108 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
