Question about Sony PlayStation® 3 (80GB) Console
My ps3 disc will not spin. I will not play ps3 games, cd's, blueray, or dvd's. I restored my ps3 system, restored my defalt settings, and deleted all files. Didn't fix problem. Herd I need a new blueray lens. Is this correct?
  • norris_j Feb 08, 2010
    Thank you for conferming, I now can order the part with much more confindence!!
  • Sony Master
  • 6,993 Answers
yes, that was what I was going to tell you to do.
The lens is weak and that's why it cannot read/load any disc plate.
I am sure the ps3 has be working fine before now. Therefore, the lens has worn out and need replacement to function well again.
Take care
Posted on Feb 08, 2010
Ps3 plays DVD and Blueray just fine, but will not play game discs... can't seem to read them. discs are in perfect condition, tried several different discs, no luck.
Some time when that happens the system configuration is wrong reset the configuration to game play on. That should let you play Movies and game.But!, make sure you remove the disk.
Aug 04, 2010 | Sony Playstation 3 (PS3) Console
Playstation3 120g not reading games, dvd's, bluerays, or netflix
Yes this is actually quite a common error to fix it you need to readjust the laser as sometimes it can get off synch.
Quite easy to do all you need is a good repair guide or you can send it in.
Jul 22, 2010 | Sony Playstation 3 (PS3) Console
PS3 READING DVD'S + CD'S BUT NOT GAMES WHATS UP ?
To start the laser reads disc's differently. A CD or DVD is just your typical disc then you have blueray which your games are burned onto a blueray disc. Your optical lens is damaged and likely unable to read blueray format.
If you have a blueray movie or can borrow one, try it and see if it still plays that will determine if that is the problem.
If so you will have to replace the optical lens,
Note: Opening your PS3 will void your warranty, so if you are still covered, it is best to send it in to Sony for repair.
Good news is it is easy to do and there are many free step by step tutorials with pictures or videos to show you how. If you must do it yourself.
Jul 13, 2010 | Sony Video Game Consoles & Games
Ps3 won't play blueray disc picture is snowy
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
May 07, 2010 | Sony Playstation 3 (PS3) Console
Not able to play games but play cd and dvd
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
• Restart System: Restarts the PLAYSTATION®3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot play game Cd's.
I wish you good luck.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont play blue ray or PS3 game discs
Please check the region code on the BD or DVD. It should match the region code set in the system. Otherwise the disc will not play
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
PS3 not loading games, CD's or Blueray discs. Have swapped over blue ray drive and still not loading so we know it is not a drive fault. Restored PS3 to factory settings and still not loading discs. Blue...
The problem itself has not been solved but after more investigation I have found out that this is currently un-repairable.
This is because the console itself has a hardware blueray drive failure due to manditory firmware 3.00 released by Sony and there is currently no fix in place.
From what I can see on the net it looks like Sony maybe being sued over this issue. Sony has also stated that they are now looking into this firmware update to see what went wrong, they have not yet made any further comment.
Oct 12, 2009 | Sony Playstation 3 (PS3) Console
My ps3 has a hard time reading ps3 games but doesnt have a problem reading anything else.
Have you tryed to play a BlueRay movie? PS3 games are stored on BlueRay so it might play DVD's and CD's, but the BlueRay's laser diode could be burning out.
Sep 12, 2009 | Sony Playstation 3 (PS3) Console
BLUERAY
if your ps3 is not set up to auto play when you insert disk. the disk should show in the menu under video menu, just select the dvd icon. If it still wont play the easiest way to figure out the problem is go to your settings menu and select reset default settings. this will reset to factory settings but wont delete and info stored in your harddrive. then try again. it should play.
Apr 23, 2009 | Sony Playstation 3 (PS3) Console
Problem with playstation 3 games and blue-ray
definitely a prob with the blueray laser u need to bring it back to shop or sony as there is no way u can fix it yourself.
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (80GB) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
