Question about Car Audio & Video
Vauxhall vectra starting problem
I have a 1998 vectra it was running sound then cut out the em light came on and i had trouble starting it when it is running it is fine vauxhall told me it was the crank sensor so i changed it and im still having the same problem what else can i do
  • TRUCKROCK Apr 15, 2008
    VECTRA 1.8 PETROL P REG NON STARTER, ENGINE MANAGEMENT LIGHT IS FLASHING. COIL, PLUGS, LEADS, ALL GOOD BUT NO SPARK. ANY IDEAS WELCOME TRYING TO AVOID TOWING IT TO
    VAUXHALL TO HAVE THE SYSTEM CHECKED
    THANKS : ANDY
  • bronx01 Jun 24, 2008
    I have a similar problem. the car will start at first and after driving when I stop and engine is switched off, it has a problem starting again as it wont go to idle. the kicks and engine start but then just cuts off. When i eventually start it will cut off as soon as i reduce speed and clutch And This is at every give way/stop sign and I have to keep cranking until it decides on its own it has had enough
The transponder in the key has packed up get 2nd hand brain transponder and chip from a good breaker its not picking up imobalizzer signal
Posted on Nov 02, 2009
Sur you have sorted out by now but coil over plugs fault, common prob
Posted on Sep 10, 2008
Airbag light on my vauxhall vectra(2008)dashboard has come on and won't go off.
Sorry to be negative,but could be anything,you need to get a diagnostic trouble code to find out what the specific fault is.
May 27, 2017 | Vauxhall Cars & Trucks
Vauxhall vectra 07 cdti 130 2.0 electrical problem?
you connected the battery wrong way (Negative to positive and positive to negative)
you have blown fuses.
check you fuses and relays
Oct 28, 2015 | Vauxhall Cars & Trucks
Spanner showing on dash when engine running vauxhall vectra c
VECTRA CAR WITH SPANNER WARNING LIGHT This Vauxhall Vectra car with spanner warning light illuminates or flashes yellow. Light will illuminate for around 3 seconds when the ignition is switched on. If the fault light illuminates whilst the engine is running, this signifies a fault within the engine or gearbox electronics system. The system will switch to emergency mode where fuel consumption may increase and the vehicles drivability reduced. A Vauxhall workshop must be consulted. If the light flashes whilst the engine is running, this signifies a fault within the electronic immobiliser system and the engine will not be able to be restarted.
Oct 25, 2015 | Vauxhall Cars & Trucks
Vauxhall vectra dti cuts out no engine lights just intermittent cuts out leave it a second or two and she fires up again !! help
Check for alternator faults--loose wire and fittings. Check for loose /dirty battery terminals
Aug 31, 2013 | Vauxhall Cars & Trucks
Vauxhall vectra 2006 looses power
have you had the fuel regulator checked a leaking vacuum hose that controls this can make it do this or it is faling.
Jan 26, 2013 | Vauxhall Cars & Trucks
Vauxhall vectra 52 plate sxi 1.8 petrol. trouble picking up speed (jolts and judders).
run the fault codes and check for injector and fuel pressure problems
Oct 28, 2017 | Vauxhall Cars & Trucks
Vauxhall Vectra Cruise control problem
try lifting the brake pedal with your toes then switching on the cc when driving. sometimes a faulty or loose switch on the brake pedal can cause cc to cut out.
Jul 08, 2009 | 2004 GMC Sierra 2500
Car Audio & Video Logo
1,277 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
