Question about LG LFX25960ST Stainless Steel French Door Refrigerator
The code er-1f displays on my control panel - LG LFX25960ST Stainless Steel French Door Refrigerator
    Problem Solver:
The codes are listed back of your ref.and what they mean
Posted on Mar 17, 2010
  • monte_60 Mar 17, 2010
    fan motor in freezer to icemaker
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
Jun 29, 2017 | Refrigerators
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
Error code Er 1F
no make no model sorry we can not help in this case
Mar 07, 2015 | Office Equipment & Supplies
Error message Er 1F
Maybe this will help. i would check fan first and see if ice has built up in fan.
https://www.youtube.com/watch?v=a4MdwuoN3jc
May 26, 2017 | Kenmore Refrigerators
Front panal displays code 1F, and pads don't function
You are probably seeing the Er IF error code that indicates a problem with the ice compartment fan.
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct. If you are advanced in technical skills, you may be able to correct this problem yourself. It will require the removal of the inside back panel of the freezer compartment. This is not an easy task. I recommend that you review the procedure for this task that is shown in the image below. Make sure that you are able to safely perform the tasks described before proceeding with this repair. Unplug the refrigerator to disconnect electrical power before accessing internal components. Once you access the ice fan, you may find excessive frost in this area and on the evaporator that could be causing your cooling problem and fan problem. If you defrost this area, you may find that you do not need to replace parts. If you find no excessive frost or the Er IF error code resumes after removing any frost then you will likely need to replace the ice fan. You can order this part here.
Click here for the image.
Nov 21, 2012 | Kenmore Refrigerators
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water or ice from lg lfx23961sw trouble code on display er 1f
Find the technical data information. It is a document somewhere in the refrigerator. It could be under the front, which, means removing the kick panel, or in the back behind the rear panel. Once you locate the tech sheet it might enlighten you are to what the error codes are. With this information you can make an informed decision as to how to proceed with your next actions.
Jun 17, 2009 | Refrigerators
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
613 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
