Question about Intel Motherboard
When booting up it stops at checking mem - Intel Motherboard
  • 60 Answers
Remove one memory chip at a time until it works. You have to have at least one to boot the computer. If you have more than one memory chip try running the computer on each chip. The one that does not work is the culprit. I fit works on none of them you might need to get another one to test with. If replacing memory does not work, you may need a new CPU. Good luck!
Posted on Feb 09, 2010
  • 67 Answers
Well your question kind of answers itself, try putting in new memory.
Posted on Feb 08, 2010
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
E-machine t6212 won't boot. I actually have two e-machines that are not sending a signal to the monitor. One is a t6212. It is booting up because I can shut it down using the windows key + up arrow +...
If you get only one BEEP at boot then the computer is working..
Do you have a 2nd monitor to test with?
if it BEEPS more then once...
pull out your mem chips and test,,
If itt works them one of the mem chips are bad if not..
pull out all pci cards and test.. if it works its a bad card...
if not unplug all HD and CD roms and test.......
If not fixed yet it maybe a onboard video problem...
But IF you put a video card in b4 the problem started then your bios may have auto set it sellf to PCI/AGP mode.
Check bios setings,, look for onbord setings for the video
Feb 21, 2010 | E-Machines T6212 PC Desktop
Computer mother board keeps beeping when i turn on pc
Usually it beep if the keyboard stuck or the mouse or mem...check with your cmos by clicking F1 or del after booting and check and see the mem and make sure that your mouse and the keyboard are connected and working...hope that help
Sep 11, 2009 | Computers & Internet
Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
Jun 07, 2009 | Intel DG31PR Motherboard
Automatic off
U Might got Commwarrior Virus Stuck ur Device -
OR U might have got Boot IC problem -
Except this No other problem Exissts -
Helped -Do 1 thing Remove Ur Mem.Card n Format ur Device -
Then Remove virus From Mem.card then Put it To Mobile -
doont do this first It might get infection to both mobile n Mem.card-
Jan 14, 2009 | Nokia 6600
Mem card slot problem
you need a new memory card reader off of ebay or amazon. OR, the game is corrupt, and the mem. stick reader stops reading because there is nomore file to be read
Apr 26, 2008 | Sony PlayStation Portable (PSP) Console
Computer will not boot with 2 gigs of ram.
yaa viz eagle is right, its really seems like frequency mismatch. The both RAM must of same size, same type, and same frequency.
Thanks
Iqbal
Mar 24, 2008 | Biostar P4M80-M4 Motherboard
Did you put a CPU in it? That's the only thing you didn't talk about in your post. Other than that, are mem modules good?
Geno
Mar 10, 2008 | Computers & Internet
Motherboard
This could be several issues. You need to be much more specific on exactly what you done and what you installed. No video boot could be the following:
1)Memory clock speed not compatible- Say board only see clock speeds of 200,266,333mhz but you installed 400mhz CL or the bios is not set to auto mem cl speed and you need to manually change mem clock speed.
2)Your CPU, memory, or video card not fully inserted
3)Memory module of video no good if it has onboard mem cells
4)You forgot to plug in the yellow/black CPU connector on the board sending no power to the cpu
5)CPU pin bent on install or not seated correctly
I could go on and on but there are a few issues that cause no video boot so double check all you cards and connections.
Oct 16, 2007 | Biostar K8M800-M7A Motherboard
Intel Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
