Question about Diamond Multimedia ( VC500) Video Capture
My Diamond vc500 constantly takes pics HELP!
My Diamond onetouch vc500 capture card constantly takes pictures every second when i open EZ Grabber. how can i solve this issue with OR without having to purchase any new items to allow change with the card? i am using windows vista 32bit operating system, i have the drivers and software, also running as admin, but still the issue persists.
HELP!
-josh
Try using arcsoft to record. If that doesnt work change the settings on ez grabber
Posted on May 04, 2013
    Genius:
  • 1,027 Answers
Check the configuration settings - you may have the automatic frame grab feature activated.
Posted on Feb 09, 2010
How do you edit with the ez grabber vc500
Hi
I give below a link to the EZ Grabber installation manual.
http://www.derbymagic.com/files/EZGrabber_manual.pdf
I have been through this but can find nothing to indicate an "edit" facility.
I then tried this link
http://www.dmmdownload.com/downloads/CURRENT/PVR/Diamond%20VC500CXT%20Walkthrough%20Response.txt
which clearly indicates an edit facility via some Arcsoft software which presumably is supposed to come with the grabber.
It is possible that one of the "software utilities" on the webpage (link below) may contain the software required.
http://www.diamondmm.com/driver-downloads.html?option=com_content&view=category&id=599&Itemid=1014&select_item=354_598&select_item_354_598=355_599
Good Luck
Aug 25, 2014 | Diamond Multimedia ( VC500) Video Capture
No Auto Stop on EZ Grab when VHS is done playing
hi, as long as you don't have a professional VHS player/recorder with a serial control, and a dedicaded software to control it, it is impossible for your soft to know that VHS as finished, you don't have the problem with a firewire input, as the control passes by the FW cable in the two directions, but you can solve that (easy way) by setting up the capture time to approach the real timing !
for the MP4 format, the easy graber doesn't capture in this format without the use of the CPU, because it doesn't have hardware encoding, so that's why you can't reach good quality by capturing directly on MP4, you would need a card like hauppage game capture to have full MP4 (H264) hardware encoding with really good quality, and without any CPU use !
Mar 13, 2014 | Diamond Multimedia ( VC500) Video Capture
Help Me remove lag please
Maybe you need to switch to another video recording software instead. Smartpixel might be a good choice for you, it is compatible with all the PC games, and it has a PIC in PIC mode which allows you comment on the webcam while game capturing, it is simple and easy.
May 03, 2013 | Diamond Multimedia ( VC500) Video Capture
When I connect my camera up to the one touch video capture card my diamond media the video camera picture flickers. Can you help me? thanks.
I had the same symptoms - black & white flickering image.
The problem was that my video source was PAL (European) but the software was set to NTSC (USA) video signal format. When I changed this, it was normal colour video without flicker.
I happened to be using AVS video recorder but similar settings probably exist in most capture programs.
Mar 28, 2011 | Diamond Multimedia ( VC500) Video Capture
No signal from Diamond VC500 Capture Device
I have a similar problem. Sometimes it works fine, but it will often have sound but no picture in the box. Other times, there is no input signal showing when I click on the gear wheel to adjust settings. There is no rhyme or reason to the missing picture. Whe I play it back, I do have the picture - usually.
Jul 18, 2010 | Diamond Multimedia ( VC500) Video Capture
I just purchased a Diamond VC500 capture card and the program won't detect the usb plugin and shows a black screen. I am running windows 7 and also whenever i try to install the driver it goes to open file...
The problem basically may be that this item is not supported under Windows 7 as of yet. No need to panic. The next option is to run your windows 7 in XP mode. It is called a virtual machine. Run your machine under XP, install the driver and then connect your capture card. you should be fine. For information on running windows under XP mode check the link below:
http://windows7center.com/news/windows-xp-mode-screenshot-tour/
copy and paste the link above to your browser. and press enter.
Jan 29, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 is not recording my Xbox 360
Mine does the same thing. I think that the problem might be that you have to go to the yellow gear thing and you have to change the recording format to DVD and you have to change the video format to NTSC_M. And make sure you have all of your hardware and your y splitters connected right
Jan 20, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture Logo
635 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Hipolito Jimenez
Hipolito Jimenez
Level 1 Expert
Lawrence Oravetz
David Gust
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
