Question about Fuji FinePix S7000 Digital Camera
The door to the battery compartment is broken/
Looking for a place to get the door to the battery compartment repaired. it will not latch. probably needs a new door put on.
    Master:
    Sergeant:
  • 411 Answers
Replace it
Posted on Mar 07, 2010
How to change battery
Hi, try:
To install the battery:
Note: To open the battery door, you will need a paper clip or thin pen.
1. Take the paper clip and use the end to press down on the door latch.
2. Holding the latch down, push the battery door up.
3. The door will slide up and spring open, allowing you to access the batteries.
4. Place the battery into the compartment. Be sure to match the (-) on the
battery with the (-) inside the compartment.
5. Slide the battery cover to its original
Jun 09, 2011 | Disney Pix Micro Digital Camera
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
Ice storm caused the doors to be frozen shut. When I finally got one of the rear doors open, I crawled into the front and kicked open the driver's side and passenger's doors. Now the latches are broken....
ok open the door and look at the latch now while you are looking at it pull the handle as if you were going to open the door the latch should move if it doesnt it is stuck all you have to do is take a screw driver or something and manually move the latch and free it up hope this helps and next time youre doors freeze shut try a warm water in a bucket pour on all edge of door and it should open a lot easier good luck
Dec 13, 2010 | 1992 Oldsmobile Cutlass Ciera
The plastic latch has broken on my Nikon Coolpix L100 battery compartment door. do you kown any way of repairing it?
Yes call the parts department for Nikon to order a new one. I have the same exact problem so I had to order the part which is 50.66 Plus shipping.
Here is the information if you need it.
Call 1-310-414-8107
the part number is 636-122-5984
Now I'm looking for instructions on how to install the door..
Aug 03, 2010 | Cameras
The door that keeps the batteries and memory card will not stay closed. Can it be fixed?
Mine is broken also. There are 2 tabs in the cover and 2 raised slots on the camera body. When you open the battery compartment, you are supposed to slide the lid forward releasing the tabs from the slots, before the cover pops open. If you don't do this, you ~will~ break the tabs (or the raised slots). Well someone who didn't know this got a hold of my camera tried to force the compartment door open, breaking the raised slots that are part of the camera body.
Take a close look at yours and figure out how this latch is supposed to work and then see which part is broken. If it's the tabs on the door you can buy a replacement door online (do a search) and have someone good with electronics install it. (requires soldering). If (like me) it's the slots on the camera body that are broken, then it's not repairable. The original parts are too small and flimsy to be repaired (designed to fail). My best idea is to find some other way to latch the door closed. I've tried a velcro strap but it doesn't hold the lid tight enough and I've looked in hardware and craft stores for some kind of latch that might work, if I could atach it to the outside of the door somehow, but haven't found anything suitable (it would have to be small but sturdy and attach to the thin plastic of the door)
I'm thinking of taking it to a jeweler because they work with very small parts and might have something that could be screwed into the plastic door and camera body.
If you know of a better fix, please let me know.
Jun 15, 2010 | Canon PowerShot A720 IS Digital Camera
Fuji S5000 camera problem....The battery door will not latch because the cheap plastic retaining nipples inside the battery box have worn down/or broken. Tape will not even hold door closed! The retainers...
You could use a piece of velcro as a strap but I would start looking at ebay or other places for the parts to fix it. Sooner or later someone will sell it.
Mar 23, 2010 | Fuji FinePix S5000 Digital Camera
Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
Jul 10, 2009 | Canon PowerShot A590 IS Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
503 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
