Question about Altec Lansing AVS 500 Computer Speakers
What are the black and green plug wires on the
On the avs500 speaker system, what are the black and green plug wires on the woofer for, where do they plug in on the computer
  • 111 Answers
The green plug goes into the "Audio Out" of your soundcard. That plug recepltical is usually also green. Unless your soundcard supports 5.1 or higher the black cable wont be used, otherwise plug it into the black receptical, which should be located right next to the green one
Posted on Feb 08, 2010
Testimonial: "This was dead on thanks"
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Tip
How to wire multiple speakers to one channel.
This mainly concerns surround sound systems, with a subwoofer. It is possible to wire multiple speakers to one channel, most useful for subwoofers. Even though bass is nondirectional, the user can still sort of place it. I create "surround bass" with one subwoofer channel. Enough intro.
I purchased two old Sansui LM-110 multi-driver(woofer and tweeter with a passive crossover) and placed them around the back wall till i liked the positioning. I then replaced my ht-z320 subwoofer with a Samsung PS-WX50(from the HT-X50 system). The X50 went in front, under the TV. The wiring to he speakers must be exactly as follows, lest the amplifier in the main unit repeatedly shut the unit down to protect(PROT then shutdown) from damage.
This is easier to do if you know how to solder(it also grants better sound), but can be achieved with a twist on wire connector and wire strippers.
The purple plug positive(denoted as a + inside a circle) keeps its wire, going to front woofer(Samsung PS-WX50) RED. Cut some speaker wire to the back woofer last on the route the wire will take to the rear woofers. Split it, then cut one of the two wires on the speaker wire at the other woofer. strip both ends. Do this to two equal lengths of speaker wire. Split and strip the joined ends of the first wire and connec both ends to the black port on the front woofer, the othe ends to the back woofer RED ports. Take the other wire, join the unsplit ends to the negative wire(helps to cut that short) in the purple plug, using your wire nut. Strip and connect the other ends to the black ports on the back woofers. This basically is a series setup. The back woofers are one one parallel circuit, but are powered as one speaker. therefore, the front speaker and both back speakers(acting as one) are a series loop. To simplify, unit + to front red. Front black to both back red. Both back black to unit -.
on Jun 13, 2010 | Audio Players & Recorders
Just got a new Dell computer. H/K subwoofer from old computer has a plug with three connections that would go in on the computer; green, black and yellow. New speakers plug directly into computer...
Could you please clarify me the subwoofer system from the old computer what brand / model is it?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 18, 2010 | Harman Kardon HK595 Computer Speakers
How do i hook up two altec lansing speakers and
Depending on the sound card installed in your system, integrated into the motherboard or not, you may need a "Y" splitter adapter. Typically, the subwoofer has a black plug while the regular speakers have a green plug. The red color is a new one on me, but let's assume that it is the subwoofer. If you have a black outlet on your computer, plug the red one into that outlet.
If your speakers came with your system, HP would have provided you with proper adapters to make the speakers work for whichever speaker system you have. If you have any "Y" adapters, use them.
Feb 23, 2010 | HP Pavilion a1610n PC Desktop
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
How to connect
Check the wires.
One wire should end with a thin green pin.
Connect the green pin to the green socket on your computer.
If there is a black pin, you have a sub-woofer, and the black pin
connects to the black socket on one of the speakers.
Connect the wire with the 2-prong silver plug to AC power, e.g., to a power-bar.
Test the speakers.
Nov 25, 2009 | Altec Lansing XA2021 Computer Speakers
AVS500 Woofer has low Freq.pulse.front and back speakers working. Need circuit diagram to trouble shoot . Henry
Is the power supply AC or DC. I had a similar problem with my boston acoustics speakers, and I was able to swap the power supply for a DC output one of the same voltage and amperage and the hum went fully away. it is an inverter circut that went bad in my woofer.
Jun 13, 2009 | Altec Lansing 621 Computer Speakers
Cant find users manual for boston micro media systems 7000596 need 2 see how it is hooked up to my computer thank u
Plug red and white cables into woofer ports that are red/white
Plug purple lead into front of woofer to input port
green goes into accessory (green) port on back of computer
elbow shaped 2 prong leads go to speakers in back
DC power goes into front of woofer marked DC input
Apr 19, 2009 | Boston Acoustics MicroMedia Computer...
I have boston ba745 speakers with woofer. The speaker wire coming out of the back of the woofer goes into computer and it's a wire with 2 plugs, a pink one and a green one. It doesn't appear to make any...
The green plug is the main audio plug for the unit. It plugs into the green jack{output} on the computer. The pink one plugs into the pink jack on the computer if there is one. Google the manual for the speakers and you might find oyut what the use of the pink one is
Apr 29, 2017 | Boston Acoustics BA745 Computer Speakers
Wiring for Altec Lansing avs500
Hi, from a very old Altec ACS48 : Green - right speaker Red - left speaker Black - common, ground White, Yellow & another Black - power switch Orange - Led indicator Below is the pin layout
Jun 24, 2007 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing AVS 500 Computer Speakers Logo
861 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
