Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
LCD TV Picture
After warming up the screen turns mostly green. Picture is still viewable but with green fill throughout most of screen.
    Scholar:
  • 133 Answers
I've seen some of these where some of the cable connectors inside of the set need to be reseated . They have become loose . Or you may have a problem in the video circuit of the set . Good luck
Posted on Mar 03, 2008
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
How to change aspect ratio on sharp tv?
You cant change the aspect ratio. You can stretch and zoom programs . Some programs like movies are in letterbox and you can stretch to fill the screen, but the results are not perfect. Circles will be oval and you will cut off some of the viewable picture. This is normal
Jun 29, 2014 | Sharp LC-32SB21U 32 in. LCD TV
My LCD tv model LN46A650A1FXZA picture turns green after about being on for 5 minutes. Then is gets fuzzy and green
I have the same issue. TV is ~ 2 yrs old. Ruled-out cable-box & HDMI cables (green present in menu mode with no cables attached).
Screen turns mostly green, with a crappy picture. After a few days, a normal picture just appeared. Today I powered-on, the green screen stuff came up, then a minute later a good picture for about 20 minutes, back to green-stuff for 10 seconds, then good picture.
Did chavez_debi get her issue resolved?
Aug 05, 2010 | Samsung LN46A650 46 in. LCD HDTV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
I have green dots all through the picture
green dots throughout the picture means the LCD is bad so unless your Vizio TV is under warranty then you would have to get a new TV cause the cost of the screen would be more then you paid for the TV.
Aug 08, 2009 | Vizio Televison & Video
46 inch Sony flat panel lcd has vertical red and green lines down right side of screen and you can be watching tv and picture will go right out and leave grayish blank screen until restart. Black...
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Apr 28, 2009 | Sony Televison & Video
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Powering up and warmup problems
why does my lcd monitor change different colors no picture just turns to all sort of colors ViewSonic N2751W 27 in. LCD Television thanks 4 your help
Dec 05, 2007 | ViewSonic N2751W 27 in. LCD Television
Lcd with bad picture
my sony bravia 40v 3000 has bad ghosting in the first 15 mis of operation
Oct 13, 2007 | Televison & Video
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
189 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
