Question about Sony KP-51HW40 51" Rear Projection Television
Kp-51hw40 hello I have this progection tv. and they told me that I need the Bulb for the projector. where can i get parts for it?
  • 1 more comment
  • nbulls34 Feb 23, 2008
    The led on front of it is flashing 8 times. There is no image. The only thing I see is black and white pixes the system shuts off after a couple of seconds.
  • nbulls34 Feb 26, 2008
    OK me and my friend took the back cover off and blew some of the dust off it. We turn it on and observed it. We notice that the center projector or gun witch its the green color turn on for a couple seconds then shuts down. The left and the right projector turn on first then the center. But like I said it only turn on for a few seconds then it shuts down. The stand by led on front of it now flashes 5 times. The person that gave it to us told us that he had it check by a tech and he told him that it was the bulb. But I dont think that is the problem because the center projector turn on for a few secs. So that tells me that its not the bulb. So if you have a different opinion please let me know. Thank you very much
  • dfwamc Mar 07, 2008
    I am having the same problem but after you keep trying to restart the television it acts like it warms up and will eventually stay on - but the colors are not correct. That leads me to believe that one of the guns? (color sources) is messed up and that it is not a problem with the power supply.
    underwodj@gmail.com Any suggestions?
  • 298 Answers
Parts for this model can be found at http://www.andrewselectronics.com
Posted on Jun 25, 2008
    President:
  • 4,402 Answers
Whats the problem your having?
if i remember correctly this has three guns, no blubs...
Posted on Feb 22, 2008
  • Cary Farah
    Cary Farah Feb 25, 2008
    · 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
    The D Board Part # A1300417A is Discontinued
    Tri State Modules Will Repair it for $140 or try ptscorp.com
    it is possiable if the crt is arcing that it could cause this, however you will need to find out which one is arcing, first thing i would do is send the board in and have it tested,if ok then you know one of the crts is bad, then your going to need a tech to figure out which on it is.
My Sony KP-51HW40 is underscan!
If you have already changed the aspect ratio on your TV, then change it on your cable or Sat box. Your TV appears to be operating normal.
Jun 17, 2012 | Sony KP-51HW40 51" Rear Projection...
Sony kp 51hw40 rear projector turn off problem .
T8005 etc is NOT the issue.
This set was prone to bad picture tubes (has 3) and can flash bright blue (most common) and set when this happens detects too much current being drawn and shuts down.
There is a fairly easy way to try to deal with this and return set operation to fairly normal.
Not technical and no parts are needed.
Let me know if you want to know with a comment here and I will explain.
Apr 17, 2012 | Sony KP-51HW40 51" Rear Projection...
Picture blinks on off
Bad bulb about ready to die out, also cooling fans, especially the small one on the projector assembly need removed and clean or the new bulb will burn out faster.
Jun 09, 2010 | Sony KP-51HW40 51" Rear Projection...
No picture but has audio with DVD and video
Try replacing bulb and clean all cooling fans of dust including projector. It is the cheapest start. After that it may be beyond you to repair.
May 14, 2010 | Sony KP-51HW40 51" Rear Projection...
Dim picture on a sony kp 53s35 53in. projection tv
hello before you buy a bulb have tried the resetting the picture go into the menu on picture setting have half way down it should say reset click it .it should brighten up the screen
regards
sha
Mar 18, 2010 | Sony KP-53S35 53" Rear Projection...
Sony TV KP-51HW40 solid red lights [timer/standby+stereo]
if the main board by chance got wet you will need to use a blow drier to try and dry it out..it may already be beyond fixing if water goi into it
Aug 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-41S3U Projector TV HV Distributor Block
The only place I know that would have your part and ship to the UK would be at the following link. Leave them a email if you dont see it listed as they only list the most popular parts they have.
http://servicemanuals.vstore.ca/
Jul 24, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
314 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
