Question about Palm Tungsten E2 Handheld
DataMgr,c, Line:7564 invalid uniqueID passed on Tungsen E2 tried reset multiple times, up to 60 seconds then I stuck it a drawer so I wouldn't have to look at the screeen
3 Suggested Answers
supportthe85
  • 35 Answers
SOURCE: Palm 505 - Windows XP Unique Sync Error
Downgrade to 4.0
Posted on Feb 24, 2009
  • 2069 Answers
SOURCE: I am getting a Fatal
With that error, the device needs to be hard reset. The hard reset will erase all the data on the device and 3rd party apps. After the reset sync the E2 and then try installing each program one at a time. Hard reset instructions here
OR,
right click on my Hotsync Icon in your start go to properties- then open file location- in this loacation you may notice two HotSync Icons, open the one named HotsyncWizard and ran it and then hit your hotsync button. It should work.
Posted on Oct 20, 2010
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Fatal Alert Datamgr.c,Line7564 InvalidUniqueIDPassed I get this when I synchronize.
Perhaps you haven't tried performing a more severe reset to break the freeze. You might want to try doing a hard reset. This will erase all data from your hand held so make sure you have everything backed up on your computer so you can sync it again after the hard reset. Note, when I occasionally receive a Fatal Alert error, the Reset on-screen button almost never responds to a tap...I invariably have to depress the reset button in the back of my E2. http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(26419) resets:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887) Depending on a variety of factors including the available memory on your E2 and other installed applications, the problem might or night not be caused directly by the program you were trying out. But once you get the E2 unfrozen, you should refer to this article to troubleshoot the cause of this apparent software conflict:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908) Also, I recommend going to the developer of the software you are using, to determine whether there are any compatibility issues at their end, and whether they have an upgrade available.
Here are the directions for the hard reset.
1. Press and hold down the power button.
2. While holding down the power button, use the tip of your stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear and then release the power button.
4. When you see the message that warns you about erasing all your data please continue and then follow the on screen directions.
If this doesn't help then I recommend going to www.palm.com. From there you will need to select PDA's and then the model of yours. It will go to another screen and you should be able to contact palm via free chat. I have had to do this several times and both times I got fast service. Hope this helps.
Aug 24, 2009 | Palm Tungsten E2 Handheld
Palm Tungsten E2 stuck on Tap the center of the target
The digitizer part is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
Best regards,
Apr 09, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Pass lock
my security locked me out but the 10 minute waiting does work, you do have to have the doors closed when resetting.
Dec 19, 2008 | 2001 Oldsmobile Alero
E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
Jul 26, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
Maytag Neptune Front Loader - E2 error code
The first time my E2 code came on the washer won't rinse or spin. I checked the drain pump to make sure it was working. (1) Take the back off and pull the two drain lines off pump. Be careful the line going to the drain has a backflow flap, make sure you don't tear it.
(2) On the other side where it drains from the washer to the pump is where I found a bobbie pin that had collected lint and was blocking the drain flow.
When it can't drain the E2 code comes on to let you know it won't rinse or spin.
Make sure to unplug machine before removing back,
Hope this helps everybody with E2 problems.
stude
40stude@bellsouth.net
Nov 29, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Palm Tungsten E2 Handheld Logo
63 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
