Question about Belkin (F5D7230-4) Router (587009)
I am having problems connecting to the internet on my desktop but fine on wireless laptop. Dell says I should check the router. Could the router be the problem and how do I determine that?
  • 67 Answers
Well there are 2 other options to consider. The router is functioning somewhat at least, since the wireless laptop can pick up the signal. So ...
#1. Check the ethernet cable... kinks overtime can damage the wires within, try a new ethernet cable.
#2 In Device Manager are there any "!" or "?" or "X" near the Network Adapters?
(right click my computer, go to properties, Hardware, click Device Manager)
If so there may be a problem with the network interface card/ports. Could be hardware or driver related.
Posted on Feb 08, 2010
Have a desktop with cable internet - installed router and added my laptop to wireless - it picked up the signal and connected and put in password no problem. Tried to do same with my cousins laptop from...
You would connect a laptop from Canada the same way as one from the US. You want to make sure the wireless card is turned on and check for wireless networks. Once you have found your network select it make sure you type the password correctly.
Dec 30, 2010 | Belkin F5D7234-4 Router
ZyXeL P320W Won't connect to internet
check weather urwireless zero configuration is disable go to the my computer right in that manage in the manage go to the services in that go to the services in that one service is there in down wireless zero configuration just start it if already start just go for the restart
Mar 28, 2009 | Zyxel Prestige 320W Wireless Firewall...
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
Limited or no connectivity on a laptop
you check your router configuration
your wireless configuration
number o hosts limited
Feb 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Problem maintaining wireless signal
Changing channel wont help,you should use specific ip setting then automatic ip setting
Jan 19, 2009 | Dell TrueMobile 1184 Wireless Broadband...
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Internet problems
anneruth:
Is your laptop/desktop getting the ip address from your router (if you have one?)
Are you on a wireless connection or ethernet?
Go to start button, connnect to, show all, double click over LAN connection or wireless connection whatever you are using, properties, then support, please let me know if you have any IP in the first line?
Also if you are on a wireless connection, make sure your wireless NIC is NOT disabled, enable it. Let me know if you need help?
Hope that helped!
Regards
Dec 17, 2007 | Dell Latitude C640 Notebook
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
48 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
