Question about Bunn -o-Matic G3 (3 lb. Commercial Coffee Grinder)
Want to grind pre-ground coffee. will it jam?
    Problem Solver:
  • 17 Answers
Probably not but it might damage itself
Posted on Feb 08, 2010
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
The problem is when I use pre ground coffee beans. The water doesn't run through. It comes over the top and the grounds get in the coffee. I buy them that way because they mark them down half price. I
There are whole coffee beans, and there are ground coffee beans, but there is no such thing as "pre-ground" coffee beans because you wouldn't want the beans to be ground AFTER making coffee.
If you have a problem using "pre-ground" beans, then STOP using pre-ground beans and grind them yourself.
I hope this helps.
Randy
Dec 01, 2012 | Coffee Makers & Espresso Machines
Can you grind hazelnuts with the coffee in our 3000 magnifica
I would not do this as hazelnuts are oily and will probably gum up the grinder.
What you could do is but a few ground hazelnuts in the pre-gound chute at same time coffee beans are grinding. These will go into brewer unit at same time as coffee.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Water does not flow through the coffee group but only exits viasteam pipe. Decalcifying and cleaning or resetting factory settings do not solve the problem. what to do?. The problem occurs after I have...
Hi
When you are finished with steaming, try pushing the steam button again and then opening the steam valve to purge the steam. Do this until the water flows freely. You should hear the pump change tone. If you have a pre grind button, try that without putting any coffee in the pre ground chute, then push a medium coffee. Water should flow through the brew unit freely. If not, you are getting a blockage in the brew unit. If it does, your grind on the machine might be too fine. Change to a coarser grind and try again. It usually takes 3 cycles before the grind is in effect.
Aug 22, 2009 | Gaggia Titanium Espresso Machine
Using the pre-ground coffee option, no coffee
The grind might be too fine or too much coffee is being added to the chamber. Try it without coffee if it works, the try with a coarser grind.
Aug 12, 2009 | Saeco Royal Professional Espresso Machine
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Bypass doser malfunctions
Happens when the preground coffee is not ground fine enough, you may have to put the pre ground coffee in a manual coffee grinder to make it finer. The machine is not really designed to brew regular coffee grounds.
Jan 20, 2008 | Saeco Magic De Luxe Espresso Machine
Bunn -o-Matic G3 (3 lb. Commercial Coffee Grinder) Logo
101 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
