Humax pvr9300t - power cycling
Pvr9300t - boots fine and plays back from HD ok but as soon as the external feed is plugged in it powercycles, over and over again
  • 212 Answers
Unplug box. Unplug aerial. Plug box back in and turn on. Do a factory reset (your recordings will be retained). Turn off box. Plug in aerial. Turn on box, do another factory reset.
That should be it.
If this helps, please write a short testimomial. This helps me to help others.
Regards
Zahc
Posted on Feb 09, 2010
What does code 576p indicate?
576p means 576 lines, progressive scan. 576 is number of visible lines on the UK system (and other nominally 625 line countries). The normal transmission system for these countries is 576i (interlaced scan), so I suspect that you are only seeing the 576p indication because there are no channels, and your TV is interpreting this as progressive scan.
The reason for no channels may be a poor signal from the aerial, or that the device (Humax or TV) has not been tuned. If you have power-saving enabled on the Humax, it will not pass on the aerial signal to the TV when the Humax is in standby. If this is the case, either turn power-saving off, or use a splitter to feed the aerial separately to the TV and Humax.
Oct 20, 2015 | Humax PVR9300T HD DVR
MY HUMAX HAS STOPPED RECORDING
Try a factory reset. If that doesn't fix it, it may need some PSU capacitors replacing.
Can you replay previous recordings?
Apr 26, 2015 | Humax PVR9300T HD DVR
How do I get my channels ITV 3, 4 5 + 6 back on my PVR Humax 9300T
You are going to need to have your aerial adjusted, it's getting conflicting signals. I have a Humax in London, not until recently was this sorted out by repositioning the aerial to the strongest signal.
Jan 08, 2015 | Humax PVR9300T HD DVR
Why is my humax pvr3900t stuck at loading a4.39?
Try switching it off at the mains for a few minutes.
Aug 08, 2014 | Humax PVR9300T HD DVR
Why is my humax pvr3900t stuck only showing" loading version a4.39" repeatedly?
Depending on its age, this model is known to need its PSU capacitors replacing eventually. This should not be an expensive job.
How can i record series options
From the Programme Guide select the programme you want and press OK. Then select the 'Record the Series' option. Note that this option will not appear for one-off programmes such as films.
Aug 03, 2014 | Humax PVR9300T HD DVR
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
Humax PVR9300t keeps freezing, have received instructions from Humax on resetting PVR to basics which hasn't solved the problem. Is now starting to freeze during recordings.
Apparently there is a new Humax software update which will be released on 3rd March 2010 - leave your box on standby that night & hope for the best.
There are a number of us with the same problem. Curently the only solution is to power cycle the box (turn off & on again from the switch at the back)
Nov 18, 2009 | Samsung SIRS4120R Receiver
Televison & Video Logo
547 people viewed this question
Top Televison & Video Experts
Electro Med Services...
