Question about Samsung HL-P5063W 50" Rear Projection HDTV
TV sometimes doesn't turn on, but eventually does, weird.
Sometimes when powering the TV on, it will attempt to turn on, but can't and ends up with 3 blinking lights. After trying many times, it eventually does turn on. This happens maybe once a month, but is annoying. Is this a sign something is broken? Also, it just recently started sometimes displaying all Green on the screen for a second or so, and then goes on to work correctly.
  • Samsung Master
  • 5,138 Answers
DMD Module Call Encompass Parts 1-800-638-3328
Posted on Feb 08, 2010
S-10 Sometimes Starts, Mechanic Can't Find Problem
Yep, heres one. Start with pulling the crank fuse. The fuse is probably good, but you have a corrosion/contact issue. Putting it back will solve this issue. I would do all of them, as one will do it, more are sure to follow. Also do they relays. Next would be checking wires. Most times wires will loose connection at the plug, sometimes they will break right at the plug.
Jul 13, 2013 | 2002 Chevrolet S-10
I have a 2006 Nissan Sentra which runs perfectly except for 1 issue. Every so often when I go to start the car, the engine will not turn over and it take 2-3 attempts for it to finally start. It always...
You need to find out what the error code is - Service engine soon means an error code was generated.
With the problem you discribed, it sounds like a coil problem. If a crack has developed in the casing, the crack size changes with temperature changes. Also make sure that the wires are in good shape.
Jun 06, 2011 | 2005 Nissan Sentra
My car is hard to start when cold and hot. But sometimes when I stop at a store, turn the engine off go in and come out. It will start right back up. Also when I start it white smoke comes out. But after a...
Assuming that you performed the basic upgrades like the spark plugs and wires. Maybe a distributor cap. I would check for this part called the crank sensor, which is pretty cheap. I had a really weird problem with starting the car during the winter which the problem started out like yours and then eventually went off to a 3 hour attempt sometimes to start the car. Once the car started, I can stop somewhere briefly and restart it. This happened to be a coolant temp sensor.
All problems with cars can be a multiple possibilities. Hope this helps tho!
Dec 03, 2010 | 1991 Cadillac DeVille
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Color wheel on DLP TV about to die
Eventually the set will refuse to power up, better to change the color wheel, as it could shatter and cause further damage in the light tunnel
Jul 22, 2009 | Televison & Video
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Lamp indicator blinks red
There is a problem with the lamp or around it? When it turns Orange, the lamp is at or near the end of it's life & needs replacing. What does the temperature indicator show? Orange, Red or Red Flashing? If not, then there is probably accumulated dust around lamp area
Dec 24, 2007 | Zenith E44W46LCD 44" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
131 people viewed this question
Henry  Thomas
Henry Thomas
