Question about Sewing Machines
I have a Designer SE and today while sewing the 'check upper thread' message kept coming up. There was nothing wrong with the thread and I rethread it several times after the message came up. I cleaned out the bobbin area with my little brush thinking maybe a sensor might be dirty. What else should I do?
    Novelist:
  • Sewing Machines Expert
  • 371 Answers
It's probably the sensor in the upper thread tension unit. If you look where the thread comes to the bottom before looping back up to the take-up lever, there is a small point coming out that holds the thread downward as the takeup lever moves up and down. Take a brush and clean any lint/dust out of that area or it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
Testimonial: "Thank you for telling me where the sensor is! The online 'expert' couldn't tell me. Thank you"
Sorry I can's solve your problem, only share your pain. I've had my machine in several times with this issue. I sat for a full day at the dealer's & when the last designs came out ok we thought it was fixed. Started again, it goes for repair again tomorrow!
Posted on Apr 23, 2010
What is wrong when the underside of embroidery has bunched thread
Hello
The bunched-up thread on the underside is the needle thread. Check that the upper thread is threaded correctly, passing through all the required thread guides and that the thread is securely lodged in the tension assembly ... there should be reasonable tension when upper thread being pulled by hand.
Also check that:
- there are no 'dust bunnies' or a piece of thread hiding in the tension assembly, and that
- the needle is inserted correctly and that it is a system 130/705H Embroidery needle.
Happy Stitching
Sewingirl/
Apr 23, 2017 | Sewing Machines
My empisal designer 800 keeps knotting the under thread when i sew
Is it the bobbin thread or the upper thread that is knotting under the fabric. Usually, it is the upper thread, which means the problem is most often the upper thread.
Install a brand new needle.
Remove the thread. Use only good quality thread--NOT old thread or bargain bin varieties.
ALWAYS RAISE the presser foot and rethread the upper thread from the beginning. Verify that the thread path is correct.
Check that the bobbin is installed correctly and threaded accurately.
Set the upper tension to the midway point and test your machine.
If there are still issues, you may need to have it serviced.
Aug 27, 2016 | Sewing Machines
Thread error message
rethread needle using every thread guide, also try changing the needle, if that doesn't help them the machine may have a computer problem
Dec 24, 2015 | Brother SE-270D Computerized Sewing...
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
Why is my thread nesting on my Babylock BMP8?
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
Jan 14, 2013 | Sewing Machines
I keep getting "check and rethread the upper thread" error message
Hi....I also kept getting the check and rethread upper thread message, I\'d sew about 15 stitches and it\'d stop. Here\'s what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slit in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slit in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would\'ve ever that it\'d be so easy and save me a bunch of money!!! I sure hope this helps someone.
Apr 23, 2012 | Brother SE350 Mechanical Sewing Machine
Sewing machine
rethread the machine & see if the thread is caught anywhere
if that doen't help turn the machine off for a few seconds & the turn it back on to see if that will clear it.
Feb 10, 2012 | Brother SE-270D Computerized Sewing...
Upper Thread Error
I just posted this under another Brother machine...mine is a se 350 but, might be the same problem!! Hi....I also kept getting the check and rethread upper thread message, I'd sew about 15 stitches and it'd stop. Here's what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slice/cut in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slice/cut in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would've ever thought that it'd be so easy and save me a bunch of money!!! I sure hope this helps someone.
Oct 22, 2007 | Sewing Machines
Designer One "broken thread"
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Feb 05, 2007 | Husqvarna Designer I
Sewing Machines Logo
117 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
