Question about Apple Color StyleWriter 2400 InkJet Printer
System required for apple color stylewriter 2400
What is system required for apple color stylewriter 2400
  • 600 Answers
Hi look up "printcountry.com, they have drivers for OSX and others.
Posted on May 16, 2010
Will a NVIDIA GeForce gt 610 graphics processor work on a Dell Dimension 2400 PC Desktop
YES, Zian it will work....BUT,....................
1) It is a PCI graphics card, and uses a PCI expansion slot.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2898922&CatId=319
The Dell Dimension 2400 Desktop PC's motherboard, has three long white PCI slots,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105465
http://www.ebay.com/itm/Dell-Dimension-2400-Desktop-Motherboard-System-Main-Board-F5949-K5148-G1548-/190750417467?pt=Motherboards&hash=item2c699c623b
http://en.wikipedia.org/wiki/Conventional_PCI
If one of those long white PCI slots is open, you can use a PCI graphics card.
Concerned that the graphics card uses DDR3 graphics memory, and your computer only uses DDR Sdram ram memory?
Don't be.
The graphics card has it's own processor (Graphics Processing Unit), and graphics memory.
It runs independent of the system resources; the Processor and Ram Memory.
http://en.wikipedia.org/wiki/GPU
The concern is the Power Supply.
Original power supply's maximum rated Wattage is either 200 Watts, or 250 Watts.
The above graphics card requires a minimum system requirement/power supply requirement; of 300 Watts.
I would recommend replacing the Power Supply.
(Especially with it's age, if it is still the same one)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
ONE thing though..............
Watch the 20-pin ATX main power cable connector, and the wires in it. Be sure they are in the standard place setup.
Check the pinout, and color code of the wires,
1) Dell Dimension 2400 desktop computer, 20-pin ATX main power cable connector pinout,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105612
2) STANDARD 20-pin ATX main cable connector pinout, and color code of wires; as set by JEDEC,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[Be aware that the ATX main power cable, and connector, you get with a new power supply; such as the above, will have a 20 =4-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Use the 20-pin connector, tie the 4-pin power cable up out of the way]
For a time period Dell was making the motherboard's main power cable connector - Proprietary.
Meaning they has that motherboard connector wire pinout changed.
Colors of wires were in a different place, than the standard setup by JEDEC.
Orange wires are 3.3 Volts (DC)
Red wires are 5 Volts (DC)
Yellow wires are 12 Volts (DC)
Black wires are Ground wires.
Guess what happens if a 12 Volt Yellow wire, is plugged into where a Black Ground wire is supposed to be?
ZZZZZZzzzzt! Motherboard fries, processor fries, ram memory fries, and graphics card. (If used)
Check the color code of the wires, in the 20-pin ATX main power cable's CONNECTOR, for the Dimension 2400's power supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Dell Dimension 2400 PC Desktop
Install Apple StyleWriter 1200 InkJet Printer on windows xp
In one word: YES
All you need are the proper drivers and I'll give you the link for the drivers.
Click Here
May 02, 2012 | Apple StyleWriter 1200 InkJet Printer
Does dell dimenion 2400 have sse2 im trying to install adobe premiere cs3
The Dimension 2400 is pretty old.
You may not have enough memory to install. Check to see what Adobe required by way of hard drive space, CPU speed, and memory.
I have no idea what sse2 is.
Jul 20, 2011 | Computers & Internet
No installed my scannar for scajet2400
Dear Friend!
Please click on following link to download HP ScanJet 2400 driver according your system requirement -
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=297431&lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=297429
Please vote after working...
Best regards,
Pramod Bhikam Singh
Apr 22, 2011 | HP ScanJet 2400 Flatbed Scanner
Is the color stylewriter 2500 just a copier?
Just a printer but could be used as a fax printer if combined with the fax software of Windows XP or winfax for Mac.
The Color StyleWriter 2500 is a color inkjet printer manufactured and sold by Apple in 1996. It was based on a Canon-developed Bubble Jet printer, but was repackaged with a new housing, firmware, and Apple's proprietary 8-pin mini-DIN serial port. The printer is similar in appearance and functionality to the StyleWriter 2400, but featured faster printing speeds: 5 PPM black, 0.66 color, vs the 2400's 3 PPM black, 0.3 color. As with the 2400, the 2500 was compatible with the Apple Pippin console gaming system. Apple offered LocalTalk and EtherTalk networking upgrades in the form of external print server devices. Also offered was a "PhotoGrade" kit, which included a special monobloc (heads and ink in one unit) cartridge with lighter photo-oriented inks and coated paper.
Sep 30, 2010 | Office Equipment & Supplies
Resolution 1024x768 stuck in 8bit color i need
If you are runnineg windowsXP goto control panel by catagory select appearence and things then display, setting, then under color select 32bit, if you are unable to select anythingother than 8 I recommend you go to DELLs website and download display driver for your system.
Nov 23, 2009 | Dell Dimension 2400 PC Desktop
Unsure if my wireless PCI adapter will fit in my dimension 2400?
You can get your systems exact specs on the Dell website under the support page. Hope this helps.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
THE PAge is stuck
use tweezers,remember to pull it out in the direction the paper normally exits the printer. if its still stucked take it to the closest service center certified by your your printer vendor.
Jun 24, 2008 | Apple Color StyleWriter 2400 InkJet...
Stylewriter 2400
HI there have you tried a new data cable? Also check that the cartridge is inserted correctly and it is an original.
Thanks J
Jan 29, 2008 | Apple Color StyleWriter 2400 InkJet...
Will not print---prints blank pages
This printer is 13 years old. I am a fan of keeping things around,  and those cartridges for $3 arent bad, but its not the best on the environment, and considering printers of this decade print faster, have better resolution and are capable of archival prints.
It's really worth it.
Hope this helps.
Oct 10, 2007 | Apple Color StyleWriter 2400 InkJet...
Apple Color StyleWriter 2400 InkJet Printer Logo
75 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Abdul Mannan
Abdul Mannan
k24674
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
