Question about Whirlpool LGB6300 Gas Dryer
Whirlpool LGB6400LW suddenly takes multiple cycles to dry clothes. It used to do a great job...now it still gets kind of hot but takes 2-3 runs to get the clothes dry. It's 6 years old. Help! Thanks!
  • 1 more comment
  • mmatrull Mar 22, 2010
    Thanks for the response. I thought the dryer was heating, but turns out it periodically will heat and then the heat shuts off. So in the middle of a cycle, while tumbling, I will check it and it will be cold inside. Yet its not always cold....no rhyme or reason to it.
    So it seems to be a heating issue. By the way, I checked all the ventilation...a little lint...but cleaned it out...made no difference on performance. Thanks.
    So it seems to be a heating issue. By the way, I checked all the ventilation...a little lint...but cleaned it out...made no difference on performance. I did NOT check the "burner intake"...how do I do that? thanks.
  • mmatrull Mar 24, 2010
    Thanks Jackfrost555 and drallim...it turned out to be the coil.
    President:
  • 1,218 Answers
Good day,
Just to make sure, double check to see if it is tumbling. If it is, and it is heating up, then it can only be an air circulation problem.
Pull off the vent hose, and check it to where it exits the house,
If that checks O.K. then you will have to break down the dryer to check the chute that goes from the lint filter down, thru the blower area and out.
Remove the lint filter, remove the 2 screws underneath
Pop up the lid, with a screw driver on the front both sides and raise, but don't go above vertical.
Remove the back cover.
On the left is a housing, that has to be unscrewed. It covers the blower wheel and and goes to the the top of the machine.
You don't have to remove it completely, just to get to the blower wheel housing.
Inspect that whole area, especially around the blower wheel, and anything that could have been dropped into the chute when the lint filter was out.
Posted on Feb 08, 2010
Testimonial: "Thanks Jack. You hit the nail on the head. It was the Coil. Unfortunately my wife gave up on me figuring it out and called a pro in. $192 later. "
  • John Hall Mar 22, 2010
    First step.
    With it off for extended time ( +6 hours). Start it with no cloths on high heat. Check to see if it is hot at the 10 minute mark. If it does, but as it continues to run it cools down, it may well be the coils on the gas valve shorting out. A common problem.
    You'll have to perform this test more than once to verify it.
    Brigadier General:
  • 4,088 Answers
Try vacuuming out the exhaust vent hose and as much of the interior air passages as possible. Soak the lint screen in hot water and detergent to remove fabric softener deposits from the screen. Vacuum the burner intake and exhaust vents as well. Hope this helps!
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
We have a WHIRLPOOL dryer model # KGYE670BWH3 and the problem is that when switching from a high to low temperature it stays high at hot rather then low temperature. but then after awhile it will go low.
Hi and welcome to FixYa. I am Kelly.
Lets talk about the physics of changing drying temps mid cycle. The dryer has built up an average temperature that is high when you had high selected. The clothes are hot. The drum is hot and the chassis / ducting is also hot. It can take almost 10 minutes for that residual heat to be removed before you notice that the drying temp has changed.
Having said that, there are a few things to check as to why it is taking an extended period to dry your clothes and why the dryer seems to be running hot.
1. Check the outside dryer vent flapper for lint build up.
2. Check the ducting for lint fromt he dryer exit to the outside vent flapper.
3. Remove the lint filter and look for lint build up around the lint filter ducting. (if it needs cleand do NOT use anything sharp to remove the lint.) A vacuume crevice tool and an old coat hanger folded in half works great.
After checking all of the above and making sure they are ALL clean, try your mid cycle change again an see if it takes less time to notice a difference.
If it is still taking a long time there may be a problem with the temp selector switch.
That is it for now.
Thanks for using FixYa.
Kelly
Mar 05, 2010 | Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Mar 15, 2009 | Dryers
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Whirlpool LGB6300 Gas Dryer Logo
243 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
