I have Magnavox Model PR1910c222 television, ser ial #40341660 where none of the buttons or remote will to anything. To turn it off, you must unplug it and when you plug it back in, it starts out on a promotional loop telling why this is the Television to buy but you cannot access menu or any other controls on the front of the TV. This is my elderly mother`s (94) tv in her rest home and is her only source of news, etc. What to do?
  • kenflo808 Feb 09, 2010
    Thank you for your quick response and probable answer to the problem. As the TV is about 15 years old and I have no electrical or soldering expertise, I shall urge my mother to invest in a new TV
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board we’ll need to check few things. When you open the unit up; take a look at the power board-the board where, the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all he inputs are going into. Also check for the Backlight Inverter Board if the sound is coming fine from the TV however as its shutting off so it should be either the power board or the main board. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 08, 2010
I have a 27" magnavox tv and it's on standby and i don't have the remote to turn it on is there any way i can get it to turn back on without the remote or can i get a a universal remote or anything please...
if there is any buttons on tv some tvs have cover over then on frount or side of any press ch.up or ch.down
is no buttons can be seen you can find remote on chylse hyde and son web site (CHS) tou will need make and model of tv
hope this helps
MERRY CHRISTMAS
Dec 14, 2009 | Philips Magnavox 27MS343S 27" TV
Captioning will not turn off ... Magnavox HD TV ... help!!
TV menu Closed Captioning CC1 2 3 4 has to be turned off. If you post a reply with your model number, I can tell you exactly how. Hope this is a good start
Jul 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
I have a philips magnavox tv with the original remote. closed caption constantly (writing script)comes on tv screen, even though the remote has a cc button,i press it until cc off comes on, the cc goes off...
You're not doing anything wrong. Your TV is somehow turning the cc on "all by itself". Some bit is getting flipped inside the TV, turning the cc on.
either that or there is some sort of rf or ir interference near the TV that is mimicking the CC button on the remote.
Have you pressed the cc button on the remote, verified the cc is "off" on the TV and then removed the batteries from the remote for a while to make sure there isn't something hinky with the remote???
Feb 27, 2009 | Televison & Video
None of the buttons on the TV will work...can't turn TV off
Hi you will need to reset your Tv & remote sounds like that children may have played with the remote reset should clear the problem.
Feb 19, 2009 | Funai MWC24T5 24 in. OLED Television
42mf231d/17 fails to turn off manually or w/ remote.
Magnavox suggests unplugging the tv for exactly 10 minutes to reset the tv---try that---or call the service number for assistance
Oct 25, 2008 | Philips Magnavox 42MF521D/37 Television
Mute and C on the screen
The TV is in factory or demo mode - turn tv off and unplug it from wall outlet for 30 seconds - turn tv back on after 30 seconds and see if problem goes away. If not, press the (volume -) and (channel -) buttons repeatedly for about 10 seconds to see if "C" will go away. If this fails call 1-888-PHILIPS for further assistance (they do Magnavox also).
May 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
Magnavox 68 cm tv model mptv68a
i have a magnavax mptv68a, the red button is on but the screen is blank, it doesn't even appear to turn on. can you advise me on what to do
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
