Question about HP w1907 LCD Monitor
On bootup monitor comes on for about 3 secinds or
Hp w1907
on bootup monitor comes on for about 3 secinds. If power off then on it does the same thing if I press menu button twice it does the same thing when it comes on it shows the desktop just as it is supposed to show but only fo about 3seconds
  • joelogan1 Mar 04, 2010
    I have removed the power supply and see nothing wrong with the caps. How can I check the power supply card to find if it is the problem?
    Also where can I purchase a new card it I need one?
    Thanks for the help
  • 11,361 Answers
Look at the power supply first for bad caps with bulging top/seal, it can also be in the inverter circuits or lamps. Report back what you see inside first so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 09, 2010
  • Bud Martin
    Bud Martin Mar 05, 2010
    I need to see the circuits bd. pictures, that will help a lot. There should be some kind of printings on the bd for make and model number of some kind, also look for 12v test point printing on the pwer supply section.
How can i hard reset my hp w1907 monitor
Thurn monitor on as its powering up press Ctrl+ F11
to do a system recovery.
Also go to www.manualmonitor.com/hp-w1907
That will let you download free manual.
Apr 23, 2014 | HP W1907 19 in. Flat Panel LCD Monitor
Power on off problem
3 capacitors are probably bulged pn the monitor motherboard. I just fix my vs17x hp monitor, but now I have another problem. but thats your problem, the 3 bad caps in the monitor. search it up.
Jan 13, 2011 | HP w1907 LCD Monitor
My grandfather has an HP W1907 desktop computer. He has been receiving a blue screen saying "Disk boot failure" "Insert system disk". Anything you can help me with?
Perhaps the machine has forgotten the bootup sequence and needs resetting. Go into your BIOS setup and reassert the hard disk as the first boot device. This also could mean that the Hard disk is bad or the operating system was not found.
Dec 03, 2010 | HP Compaq WF1907 Monitor
The power button flashes between blue and yellow. The monitor screen stays black. I have the exact same monitor and switched it on to my other computer, and the computers are both working fine.
perrycdoq, Did you do flashlight test? Is your monitor also "blank"? Did you visit this old net blog? http:///www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading there then come back and tell me if you think same thing might be wrong with your unit. Will you do the troubleshooting or contract out the work to qualified electronics technician to fix units "switch-mode-power-supply / inverter ballast circuit? 12fixlouie
Oct 03, 2010 | HP w1907 LCD Monitor
My HP W1907 monitor needs a driver update. Told access is denied
yes the monitor bad , which means your lcd lamps gone ....
May 09, 2010 | HP w1907 LCD Monitor
My hp w1907 monitor has suddenly stopped working!!as soon as i turn on the tower it just displays"monitor is going to sleep"PLEASE HELP!!!
I love this one. I've actually done this many times before and have been successful.
1. Turn the computer off and unplug the power cord from the back of the tower.
2. Press and hold the power button for about 3 seconds while the computer is unplugged (this drains the remaining power from the capacitors on the motherboard).
3. Plug the computer back in and turn it on.
If that does not work, follow steps 1 and 2 again, but this time:
3. Open the computer while it is unplugged and unplug the power supply from the motherboard then hold down the power button again for 3 seconds. (You may also want to take the RAM out and put in back in)
4. Plug everything back in and turn the computer on.
Mar 13, 2010 | HP w1907 LCD Monitor
My hp w1907 monitor goes dim after start up. It
More likely to have problem in the power supply, back light inverter circuits, or worst will be bad lamps. Look for bad caps with bulging top first, post back what you see so we can guide you further, see example of failed monitors mostly due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | HP w1907 LCD Monitor
Monitor going to sleep upon Bootup.
Open your cpu cabinet.
refix your RAM memory .
Pull cmos cell for 10 minutes so all settigns are defaults.
Also remove PCI cards from PCI slot .
Then check.
Let me know if you need more assistanse.
thanks.
Aug 31, 2009 | HP w1907 LCD Monitor
HP W1907 Monitor
If it was working fine why install additional software? Try booting into safe mode and uninstalling the software or drivers.
Jan 03, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
326 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
