Question about Philips 42FD9954 42 in. Plasma HDTV
Vertical Lines Have good color and sound, but have very light blue and red vertical lines in the picture. They are evenly spaced across the screen. Like it needs a convergence adjustment, but the color is okay.
  • Bob Browning Feb 23, 2008
    Hello, It is the vertical lines , not blue speckles. I cannot find the grey screw (adjust pot ? ) on the small (4x6) vertical board on the left side . Is it on the PDP board ? I have the service manuel on CD. Thanks
  • Bob Browning May 06, 2008
    Found the problem with the vertical lines to be on the board below the "SCAVIO" board. Replaced it with a good board from another set and all is okay. I believe this board interfaces with both PDP boards.
  • Philips Master
  • 19,396 Answers
Hi I can try soling your problems
Posted on Feb 22, 2008
  • Ginko
    Ginko Feb 22, 2008
    Being a plasma tv is not a convergence adjustment that you need. Vertical lines are usually a panel fault which isnt cheap to fix. If instead you have blue speckles, they are fixable just a voltage adjustment. If you feel confident enough you could try this yourself. what you would have to do is take off the back panel if you have a stand put it back on that. easier to work on. then plug it. BE CAREFUL not to touch anything inside!!! from the back you will see a board on the left side on that board will be a small board attached vertically it will have a gray screw attached(very small). with the tv on you adj. the screw until the blue goes away(a little does alot). In any case, before doing all this you should check all contacts inside your tv, by disassembling and testing them.
    Hope it had been helpful.
    regards
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vertical lines appear on screen...
You have a defective light engine. Contact RCA support. Sometimes they will warranty these even after the 1yr warranty has expired.
May 16, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Philips 42FD9954 42 in. Plasma HDTV Logo
226 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
