Question about Refrigerators
My Admiral Ultima leaks water in the refridgerator part and started making weird noises when it starts up. Today ice started to form in the vents , that are inside under the freezer. I have to keep a bowl there so the food, bread etc. doesnt get wet.
  • 572 Answers
Ur drain is clogged have to open the freezer back panel. defrost unit first
Posted on Feb 08, 2010
Frigidaire refridgerator leaking in icemaker
Try buying a new ice maker kit and replace it by doing it yourself. This would help you in saving money.
I recently bought a ice maker kit at lower price from Partsimple.com. they delivered it faster compare to others available in market and that too at low cost. Isn't that Good?
Try searching with compatible model no on Partsimple website.
Feb 11, 2013 | Frigidaire Refrigerators
Admiral washing machine will not start
admiral washer machine will not start and before it died there was a weird noise coming from the machine.
Jun 28, 2010 | Admiral AW22 Top Load Washer
My admiral refridgerator ia aproximately 20 years old.It makes a popping noise almost daily,usually at night.What is this ?
The popping noise is water evaporating or dripping on the defrost coil its a heating element that defrosts the freezer section with a heat coil like in your oven on a smaller scale.
Mar 08, 2010 | Admiral AAV7000A
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer fan starts sounding like its rubbing louder and louder on a french door model 79577312600. if I unplug it clean out the food and use a hair dryer to defrost behind the inner skin at the center vent...
you are correct. it is not the fan causing your troubles.
you have water getting into the fan blade and freezing next to the blade causing the noise.
the ice maker is the most common problem. it maybe leaking behind the panels and causing water to form ice then get into the blade and make the noise.
shut the i/m off for a few days and see if this stops the noises. if so, then check the fill tube, its a plastic tube from the rear of the unit into the i/m. if it is overflowing and leaking then you might need to adjust the tube so it doesnt leak when filling into the i/m. its somewhat simple but may seem hard. just put some type of a sealant around the tube to prevent water from running out of the tube.
if this doesnt fix the problem, then you may have an i/m that needs replaced. but dont do that first. the tube is usually the problem.
Jan 08, 2010 | Refrigerators
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Several problems with ice maker
i suspect he real problem is that the freezer is not defrosting. its difficult but take off thge back panel in the freezer and see if there is ice build-up on the pipework behind.if so melt it off with a hair-dryer and check also that the drain is clear. the water you have had on the floor could be due to intermittant defrosting
Mar 14, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
231 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
