Question about HP Officejet Pro L7680 All-In-One Printer
A black vertical line is on each copy.
Hp L7680 all in one printer
when i print something there the copy comes out with a black vertical line on the page.
  • 60 Answers
Try the 6500 driver. I have seen that allow text print but no graphics. If line disappears, reinstall 7680 driver. If line comes back, contact HP about updated drivers, check their website OR try to get your money back. I have never had luck with this series of AIO.
Good luck.
Posted on Feb 09, 2010
How do I clean HP officejet Pro L7680 All pictures have severe vertical lines??
Have you tried the "clean print head" option in the HP Officejet Pro software on your computer? This will often fix verticle lines. But, it will use a lot of ink.
Nov 04, 2014 | HP Officejet Pro L7680 All-In-One Printer
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One printer. copies come out black
Probably either the scan lamp or the sensor bar has failed. Do you see the scan lamp glowing under the cover when you try to scan a document? (Lift the edge of the cover slightly and watch the underside of the cover, you should see the reflection from a bright bar of light moving from one end of the original to the other. Do not look directly down into the light if it is on!)
Nov 25, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have a newly installed black ink cartridge but the black ink won't print properly - cuts words horizontally and vertically (lines)!
hi
you need to clean printheads via maintenence menu of your printer
in case you still get bad printing you need to replace the printhead
that has bad printing results
The printheads are getting dry if have n't been working for a long period
Kind regards
Dr Print
Dec 14, 2010 | HP Officejet Pro L7680 All-In-One Printer
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 black print streeks every 5-6 lines
Any inkjet printer with this problem is caused by a build-up of ink on the undercarriage or the wiper assmbly.Usually on the right side where the cartridges are at rest. You have to get messy and clean that build-up with moistened cloth, qtips etc.
Jul 30, 2009 | HP Office Equipment & Supplies
HP L7680 prints red instead of black
Check your default ink setting if red is default then change it and make black ink default settings.
Thank You
Jul 28, 2009 | HP Officejet 5610 All-In-One InkJet...
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
2 vertical, parallel, black, lines print on copy
Sounds like it could be bad cartridge or scanner. Try replacing cartridge first cause this is pretty easy to do and is alot cheaper.
Feb 11, 2009 | HP Office Equipment & Supplies
HP Officejet Pro L7680 All-In-One Printer Logo
340 people viewed this question
Seeker5211
Seeker5211
