Installing Windows on new PC with Sata hard drive with no operating system installed
My son has just bought a new PC with a Sata hard drive. When I start it, an error message says press any key to boot, but this keeps repeating. I've gone into the Bios and changed the boot drive to a Windows CD but it does not run it, neither will it go to the C:/ prompt
I'm wondering do I need to format the drive first and if so how when I can't get it to the C:/ prompt?
  • Stephen Cord Feb 22, 2008
    http://fdisk.radified.com/ does not seem to refer to Sata drives. Are they treated the same?
    I'm trying to install Windows XP Pro from CD, but pressing a key just repeats the error message
  • 34 Answers
Press any key to boot...
usually that comes up when a cd is inserted and its waiting for you to press a key so that it boots the cd
Formatting shouldn't be necessary if its a new pc unless your trying to get rid of the operating system.
Are you trying to install windows xp / vista ?
Posted on Feb 22, 2008
  • Macrin Sosa
    Macrin Sosa Feb 22, 2008
    forgot to ask
    is the hard drive recognized in the bios ?
    if it is
    have you tried using the hard drive manufacturer format utility
  • Macrin Sosa
    try going to this website
    http://www.ultimatebootcd.com/download.h...
    Download the exe.zip or iso file
    and then write the iso file to cd
    using imgburn or any other program
    President:
  • 4,402 Answers
New hard drives you have to fdisk and then format
  • Cary Farah
    Cary Farah Feb 22, 2008
    sorry i didnt see sata..
    when you tell bios to boot you need it to boot from the cdrom
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Windows can't install because it says it can't find a hard drive. Setup indicated both HD's are there and working. Installing Windows 2000 from Disc. Changed boot sequence so Rom boots first. Windows loads...
Check for sata drivers, if it is system is shipped with SATA hdd, need to install SATA Raid drivers during reinstallation .I believe that the dell system was originally shipped with Windows XP or Vista Operating system which has SATA drivers for SATA hdd. Since windows 2000 Operating system does not have SATA drivers hence unable to recognised hdd.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
Can't install WINDOWS.
Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
Updat to new sata hard drive from old idie hard drive.wont reconi
Hi, you will need to load the sata raid drivers when installing the OS. Some off the older versions of xp will not have these, when windows is installing it will ask if you need to install a 3rd party raid driver press F6. later on it will ask you to insert the raid driver disk. which you may have to do/make yourself if you haven't already got one.
Mar 01, 2009 | Computers & Internet
I am facing Problem installing Windows XP with Asus P5RD1-VM series mothboard with SATA Hard drive. My harddrive doesn't get detected while installing Windows XP. While going for coping files for...
I would go into the BIOS and make sure your SATA controller is using the AHCI or IDE setting and not RAID, if it is using RAID then it may need to load a special driver to install windows.
This is the most likely cause of your problem, can you also check and make sure the bios is seeing the HDD at all?
Jan 21, 2009 | Microsoft Windows XP Professional With...
Hi!
You need to copy the SATA drivers from the motherboard CD into a floppy diskette.
When you are booting with the windows xp installation CD you can see a message that says:
Press F6 for raid drivers
Press that key so windows installation CD look for the SATA drivers.
Jan 20, 2009 | Microsoft Windows XP Professional With...
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Windows XP SP2 will not boot after installing new SATA hard drive
Your system thinks the "second" drive has precedence over the first ( your boot drive ) try switching the SATA cables between the two drives. There also might be a BIOS setting under Boot Order, sometimes you have to drill down to get to it for a particular drive.
Dec 25, 2008 | Microsoft Windows XP Professional for PC
SEAGATE HARD DISK DRIVE PROBLEM...
just remove the jumper settings of the HDD like this one.;
choose the master without a jumper.
let me know
Oct 04, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Computers & Internet Logo
208 people viewed this question
Alun Cox
David Payne
David Payne
