Question about DeLonghi BAR 140 Espresso Machine
Ok light does not turn on
I just purchased my 140 today and i cannot get the "ok" light to turn on to tell me the temperature is correct...how do I resolve this
  • SIERRADOGG Oct 26, 2008
    I HAVE THE DELONGHI EC-140BC AND THE OK LIGHT DOES NOT COME ON. I READ THE ONE SOLUTION ABOUT TIGHTENING THE SCREWS IN THE MACHINE. MY QUESTION IS "WHERE DO YOU OPEN THE MACHINE TO GET AT THESE SREWS AND WHAT KIND OF TOOLS DO YOU NEED ?
    THANKS,
    JOE
    sierradawgg@yahoo.com
  • 833 Answers
If this is a new unit, you should return it. If you don't have that option, you'll have to open it up and tighten some screws that hold the wires into their respective barrier strips. Delonghi often doesn't tighten them quite enough. The unit will sort of work. The problem may be finding all the screws to remove to get in and that some of them are 'tamper' style. It is also possible that the temp sensors are not fitted right or are defective. Good luck.
Posted on Feb 23, 2008
I have a Sharp printer Model AL-2040CS (purchased in 2010). This error message flashing "H 4" on my screen.
H4 00 Content Main heater lamp abnormally low
temperature detection
Details The setup temperature (about 90°C) is not
reached within the specified time (about
17sec) from turning on the power ON SW.
(When the temperature of main heater
lamp thermistor falls below 140°C in the
standby mode or printing.)
Whether temperature of main heater lamp
thermistor falls below 50°C in the pre-heat
mode.
Cause Main heater lamp thermistor defect
Main heater lamp failure
Main thermostat failure
Control PWB failure
Check and remedy
Check the heater lamp blinking with SIM 52.
When the lamp blinks normally:
Check the thermistor and the harness.
Check the MCU PWB thermistor input
circuit.
When the lamp does not light:
Check for disconnection of the heater
lamp and thermostat.
Check the interlock switch.
Check the power PWB and the MCU PWB
lamp control circuit.
Clear the display of self-diagnostics with
SIM 14.
Dec 15, 2017 | Sharp Office Equipment & Supplies
Why does my Tp Link M5350 3G wifi turn on and off?
When ”high temperature” shows on the OLED screen, the device is too hot, so place it in a cool, ventilated location. When the temperature is high enough, the device will stop charging/functioning in order to avoid damage.
This device responds to overheating whether or not it is charging.
When the device is charging:
• The device is powered on. When the temperature is higher than 113°F/45°C but lower than 140°F/60°C, it will not show “high temperature” but it will stop charging.
• The device is powered on. When the temperature is higher than 140°F/60°C, it will power off & stop charging. Also the OLED screen will show ”high temperature” at that time.
• The device is powered off. When the temperature is higher than 113°F/45°C, it will stop charging & the OLED screen will show ”high temperature."
When the device isn’t charging:
• Only when the temperature is higher than 140°F/60°C, will the OLED screen show “high temperature” & this device will power off.
May 04, 2015 | Computers & Internet
My sewing machine will not pick up the bobbin thread. I have rethreaded both and still no luck. I was sewing earlier today and have no idea what went wrong. I have changed the needle
make sure the bobbin is spinning in the correct direction, and that you are turning the hand wheel in the correct direction.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Singer Sewing Machines
We purchased a 2013 camper with a dometic refrigerator and today the temperature is up to 48 degrees
move temp sensor in fridge lower or let hang if ok tomorrow replace if not bad sensor
Sep 22, 2012 | Dometic Refrigerators
The oven does not cook the food, it only warms the food.
Two possible problems. If the oven has two or more elements for normal operation then one of these elements may be faulty. The thermostat may also be faulty and only heating to a far lesser temperature than required. The way to tell is turn the oven to a normal cooking temperature.
If the oven indicator light stays on all the time and doesn't cycle off then it may be an element problem, meaning that the oven can't reach the temperature setting desired.
If the oven indicator light goes off after a while and then cycles on and off then the thermostat is working correctly but the temperature may not be hot enough. You may have to purchase a small oven thermometer and check the oven temperature against the thermometer to get a better idea of what the problem is.
Feb 10, 2011 | Viking Ovens
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
I had a MC-91 US Rinnai tankless water heater installed in my home last Monday a week ago today. The temperature is set at 120 degreres. The problem is when we take a bath. The hot water only lasts till...
I would suggest that you turn temperature setting up to 140 degrees and see if this won't help you. Obviously with water temperature that high make sure no little ones are left unattendded. Thank you
Nov 23, 2010 | Rinnai Heating & Cooling
System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 Is the wiring from the DC controller PCB to the fixing film unit normal?
 NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
 Try replacing the fixing film unit. Is the problem corrected?
 YES: End.
 NO: Replace the DC controller PCB.
Jul 28, 2009 | Canon imageRUNNER 2000 Copier
DeLonghi BAR 140 Espresso Machine Logo
97 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
