WASHER JUMPS AROUND ON THE FLOOR - Washing Machines
  • 12,061 Answers
This is usually due to the balance weights coming off the drum, or the machine has an unbalanced load. or it is not level.
Posted on Feb 08, 2010
Bosch Exxcel Vario Perfect washer
What You Do is go and get Yourself a Sheet Of Thick Plywood, At Least 3/4", Get Marine Grade because the Glue Will stand up to Water. If you are installing this on a wood floor, you might want to put a few Screws Where you can Screw into a Joist Having the wood Wider than the Washer is a Good Thing, Washers Inherently want to Jump Around, Sounds like your floor is acting a a springboard, you can double up on the Plywood too.....~~*BB
Jan 03, 2018 | Washing Machines
My new front loading LG washer jumped around and moved across the floor the first tiem I used it. What's wrong?
You failed to remove the shipping bolts with spacers (4) from the back of the washer.
Apr 12, 2011 | LG Washing Machines
Forgot to remove shipping bolts from the washer. did 2 loads. did i do any damage to my brand new frigidaire?
Probably not, but I bet it did a little jumping around and floor vibrating. Those bolts just lock the tub in place so that it doesn't fall off the tub hangers.
Mar 17, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer jumps all around during final spinn
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
Regards
Berry
Feb 04, 2010 | Speed Queen ATS90AWN Front Load Washer
How do you keep washer from jumping around during spin cycle? The washer is on one of the Maytag storage stands. It is leveled on a concrete floor but jumps around when on medium or high spin cycle. Any...
first of all if this is a new washer you need to make sure all the shipping straps or bolts are off. one way to find out is to open the door reach and grab on to the tub it supposed to be able to move up down and side to side. if not then the shipping bolts has not been removed.
Nov 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Can not keep the HE 3 washer from jumping around on the spin cycle. Floor is level and machine is level with legs locked in place. Have lowered leveling legs to the base and locked them tight with the...
these machines can have this problem when placed on a pedestal and/or the floor may be level but not solid. a "bouncy" floor will amplify any movements. remember, these machines are much heavier and spin much faster than top-loaders. just because it doesn't jiggle doesn't mean the floor is level. you may have to brace to floor or foundation somehow
Sep 24, 2009 | Kenmore Elite 45986 Front Load Washer
Noisy washer and jumps around
It could be a few different issues. Check to be sure your washer leveling legs are set correctly. Also many newer washing machines have what they call shocks, stabilizing struts. Those can fail over time and cause your machine to be off balance and walk the floor/vibrate. When is the machine nosey? If when its filling with water it could be a water inlet valve. Or during the spin cycle it could be a drum roller, belt, pulley, Or top bearing glides to name a few things.
May 24, 2009 | Whirlpool WTW5300SQ Top Load Washer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer off balance
Check your skate plate assembly or Base pad. these are the leading reason why the machine will be jumping around.
If these are in tack.
Please specify minor repair.
Feb 11, 2007 | Whirlpool GSW9800PW Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
