Question about Samsung Televison & Video
Cable light keep blinking no matter what button is pressed...can't change channels, turn off/on tv with remote
ice man
  • 68 Answers
SOURCE: after programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Posted on Mar 25, 2007
dinomb
  • 16 Answers
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Posted on May 11, 2008
SOURCE: Samsung ltm1555B - lcd tv blinking on button
I am having the same problem with the blinking orange light
Posted on Aug 31, 2008
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
  • 27 Answers
SOURCE: Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
please rate my answer it is much apreceated
Posted on Feb 13, 2009
My UR5U-8700L remote doesn't change the channels, but I got it to turn the TV off and on. How do I program it to change channels from the cable box?
1) Press the “Cable” button at the top of the remote to put it into Cable Box control mode.
2) Press and hold the “Setup” button until the “Cable” button blinks twice.
3) Type in the code 994. The “Cable” button will blink twice
Mar 06, 2010 | Televison & Video
Im trying t0 program a Phillips TV with a RCA niteglo universal remote.
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
Codes:
0154,1174,0062,0204,0004,0184,0208,0205,0206,0207,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0140
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | RCA Universal Remote 3 Device Remote...
Sentry RMC-10 remote can't 'discover' my tv's code
.there are several codes. try each one seperate.
CODES:1171,0116,0167,0176,0922
Aug 28, 2009 | Sentry SE-RMC10 Remote Control
Programming my hitachi remote
CODES: 0545,0529,1754,0509,0465,0513,0518,0530,0531,0464,0511,0533,0526,0463
Aug 28, 2009 | Televison & Video
Need codes for rca remot control have phillps tv
CODES: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
Aug 28, 2009 | RCA Universal Remote Control
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Kidz Remote
RE: Programming a Kidz Remote by Kissel By helpmedave (Guest Post) 1x1.gifthe procedure to program the remote is as follows.
Find the setup button recessed between tv and cable buttons. Use a toothpick to press the setup button until the led blinks once, keep holding it until it blinks twice then release. press tv or cable button then enter the 3 digit code for the device you want to try. the light will blink twice if the code is valid. ( yeah i know you don't have the codes ) (me neither ) if you successsfully program it to control a device, you can then program each button as follows. hold setup button until light blinks twice.press tv or cable as needed. press 995 the led will blink twice . press the button to program. enter channel number you want (may have to enter 2 or 3 digits 08 008 etc)press setup light will blink once.m select another button and repeat to program all buttons you wish to program.to lock in settings, press setup until led blinks twice. good luck.Posted on 08/09/2007
Jul 16, 2008 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Jun 08, 2008 | Big Button TV Universal Remote
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
