Question about HP ProBook 4510s FM849UT Notebook
Charging Problems When I Connect The Charger To My Computer It Says "Ac Adaptor Too Low For This computer" Wat Can I Do To Fix That?
    Problem Solver:
  • 3 Answers
If The Computer Is On Power Saving Mode Take That Off Cause That Is Wat Often Causes The Problem. It Worked For Me =]
Posted on Feb 09, 2010
  • 60 Answers
AC Adaptor is probably bad, the result of plugging into an unprotected AC outlet. Make sure to use surge protectors (NOT just a power strip) and get a new one. This happens ALL the time. Plug into surge protectors, keep one in your laptop bag if necessary.
Lattitude e5520 wouldn't charge
Ted try this once more:
1. turn off the machine.
2. keep pressing the off switch a little longer 3. remove the battery.
4. press the off button for say 15 seconds.
5. re-install battery after a few minutes.
6. connect charger to computer and see if it shows % charge.
7. when it shows 100%disconnect charger and see if the battery still shows 100% If it does you are now reset. IF not,will cross the bridge then.
Jan 24, 2014 | Dell Latitude E5520 Laptop Computer PC...
My usb cable will not charge my psp
Are you plugging the charging plug into the PSP?There are two plugs on the USB cable 1.the USB plug. 2.the charger plug itself. The USB cable looks like the other end that plugs into the computer only smaller.The charger plug looks like the ordinary AC adaptor.
Also note that You need the computer/device that the PSP is connected to,must be turned on,well this is true with mine anyway.
Also the USB does not charge the PSP as fast as the AC adaptor.
Oct 02, 2010 | Sony PlayStation Portable (PSP) Console
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Apr 16, 2009 | Garmin StreetPilot c340 GPS Receiver
I pod problems
Hi
I think your battery may be going bad or you need to purchase a wall charger to fully charge your battery. Charging your iPod on your computer works fine for a while, but as the battery gets older, it needs more charging and often it doesn't get enough from the computer. Try a wall charger first. Charge it all the way up until it stops charging. If it still shows a low battery you need to have a new battery. There are a lot of places that can do it. Hope that helps.
Dec 20, 2008 | Apple iPod MA446LL/A MP3 Player
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Panasonic VDR-D250 - PC Connection problem
I have the same camera did u click on finalize or something and then its says connect to ac power if yes just get your battery charger and u get this thing that helps u see explore ur camera by also charging the battery at the same time just connect it to the camera and it wont say anything like ac power afterward.
Jan 20, 2008 | Panasonic VDR-D250 DVD Camcorder
HP ProBook 4510s FM849UT Notebook Logo
116 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
