Question about Epson Stylus R265 InkJet Photo Printer
Iwant to clean out or change waste ink pad on epson r265 printer. have just used cotten buds to soak up waste ink to fix flashing lights. but i think only a temp. solution
  • 75 Answers
You need to remove the following parts before you can remove and clean out the waste ink tank.
Paper support tray. printer cover. front cover Right and left housing abd usb port then the silver bar holiding the tray in place remove the screws from the tray and the waste tube and remove the tray
inside the tray you have a number of ink pads of different sizes
remove them clean off your tray and replace them with new pads or you can wash out the old pads dry them off with a hair dryer and reuse but it is a messy job when you finish you need to restet the printer.
Posted on Mar 20, 2010
    President:
  • 2,678 Answers
Photo walk through here shows how to access waste pads
http://www.inkrepublic.com/KnowledgeBase/R260WasteInk.asp?C=0
Also shows how to replace with a bottle to collect waste ink
Posted on Feb 08, 2010
Testimonial: "Still not show how to clean out waste ink pad. But good info anyway, thanks. 99johndoe"
Reset epson r265 printer
Actually it's just the waste ink pad inside the printer that needs to be cleaned or changed and often this pad is not full with ink at all and therefore the service indicator and waste ink counter can be safely reset. A niffty piece of free software is avaiable to do just this. Go to this site:http://www.ssclg.com/epsone.shtml and download the latest version. Operating instructions are on the site and it's very easy to use. This will save you quite a bit of money for now but I would remommend that the next time a service warning comes up that you should then have the printer serviced as eventually the waste ink pad will become full and need cleaning or replacing.
Jun 18, 2010 | Epson Stylus R265 InkJet Photo Printer
My Epson R265 is sending a message saying that it
If the lights are flashing alternately and slowly (with the power light off), then the waste ink absorbers are full.
The pads are near the bottom of the printer and can either be replaced (call the service department for the parts) or rinsed clean under running water. The hard part is usually extracting them (you need to disassemble the printer most of the time). Then (if reusing the pads, wait until they are dry) reinstall them and reset the waste ink counter. The reset requires a program such as the one available here: http://inkjetprinterhelp.us/epsonSSC.html . Do not run this utility until the pads are replaced, the ink will smear everywhere. Epson used to have a link for their own reset tool but I do not see it for this printer.
However, the printer is designed that under normally usage, the waste ink absorber will be full at the expected end of life of the printer. Thus additional failures may be coming.
I hope this helps.
May 04, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
2 RED LIGHTS FLASHING CARRAIGE WILL NOT MOVE
On the Epson printer two flashing red lights mean that your printers waste ink tank is full and Epson has locked your printer you need to replace the waste ink pads and then reset your printer using the reset utilities
Mar 08, 2010 | Epson Stylus R265 InkJet Photo Printer
Need to clean waste ink pad on epson r265 printer
You need to remove the Paper support tray, printer cover front cover usb housing and right and left housing then remove the waste ink tray inside the tray you will find about 12 pads that need taking out you can just replace them with new ones or wash and dry them and re-install them the latter is very messy then refitt everything and then you will need the service utility to restet the printer If you need further help email me at drummerboy36uK@yahoo.com or try me on msn messenger using thedrummerboy53@hotmail.com
Feb 08, 2010 | Epson Stylus R265 InkJet Photo Printer
How do you reset the epson r265? I have 2 flashing red lights,
Two flashing lights means that you have a problem with your waste ink pads being full you normally get a warning first to say you need to have it serviced then your computer gets locked out
You need to replace your waste ink pads to do this you can either
take it to an epson service agent which will cost in the region of £50 or try doing it yourself when you have finished replecing your ink pads you need the printer resetting to do this you need a reset program you can find these free on the internet
If you need any help email me on drummerboy36uk@yahoo.com or throughmsn on thedrummerboy53@hotmail.com
Oct 22, 2009 | Epson Stylus R265 InkJet Photo Printer
Lookin to bypass service required for epsom r265
Hi, I have come across this problem with Epson printers in the past. What it is wanting you to do is send it in for a 'service'. Actually it's just the waste ink pad inside the printer that needs to be cleaned or changed and often this pad is not full with ink at all and therefore the service indicator and waste ink counter can be safely reset. A niffty piece of free software is avaiable to do just this. Go to this site: http://www.ssclg.com/epsone.shtml and download the latest version. Operating instructions are on the site and it's very easy to use. This will save you quite a bit of money for now but I would remommend that the next time a service warning comes up that you should then have the printer serviced as eventually the waste ink pad will become full and need cleaning or replacing.
Aug 19, 2009 | Office Equipment & Supplies
Epson r265 sevice require
how much for a new waste ink pad in the uk ta
Aug 10, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265
Both redlights are flashing, and I need to change the waste ink any one help please
Apr 24, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265
ok the only website you will need to sort out your problems on flashing lights - I kinda liked them when i switched my room lights off. anywayz here's the site:
http://www.eserviceinfo.com/index.php?what=search2&searchstring=EPSON+RX420-425-430
under the heading 'file' you shall find your program (R265 RESET.rar). click on it then another page shall load, go right down to the bottom it will say Download >> To download the file, please, click here ! << Download help.gif
well there you go the direct link to download the program no need to go through the website.
Over and Out guys.
Sep 12, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
772 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
