Question about Microsoft Xbox 360 Console
Red flashing on bottom left ring and not loading properly
It fell off and wont turn on properly??
  • damonumber5
    damonumber5 May 11, 2010
    What is the E number on the tv, its at the bottom of all the writing on the screen, your console may be able to be fixed by microsoft for free. What fell off?
  • 78 Answers
Greetings,
Please go through the Website link mentioned below.
http://support.xbox.com/support/en/us/xbox360/hardware/console/troubleshootingconsoleproblems/flashinglights.aspx
Please let me know if you have any issues.
Regards,
Posted on Feb 11, 2010
My tomtom fell on the floor and i get aflashing red and white cross. How do i correct this and get my device working again?
Internal memory was damaged when dropped.. OR the SD card if it has one. Replace the sd card and copy data over from back up
Feb 23, 2013 | Tomtom ONE XL GB Car GPS Receiver
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
3 red light flashes. left top. left bottom and right bottom. Problem occurs when power is turned on. Read manual and contacted you.
You've got the three red rings.
They light up when there is a general hardware failure in your Xbox.
If your xbox is under 3 years old, contact Microsoft and they'll service it.
If it's over 3 years old, wrap it in a towel, turn it on and let it run.
This is a simple, yet effective temporary fix.
Mar 09, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
It just wont work
If you have 3 red lights on the ring you have what they call RROD or red ring of death. Bottom right would be hardware failure.
DVD Drive failure most common problem, this ranges from dirty disk error (DDE) message to inoperable drive door, skipping in movies, slow load time or no load or the call customer service errors 10, 11, and 12. To replace the drive it will have to be reflashed.
Feb 18, 2009 | Microsoft Xbox 360 Console
Flash problem
I believe you're pushing the wrong button. The way to turn the flash on/off is to push the top part of the ring that surrounds the "FUNC SET" button. This is the same ring that you push left/right to scroll backward/forward through the pictures you've already taken. Similarly, you push the bottom of that ring to turn the "macro" function on/off. Hope this helps.
Nov 11, 2008 | Canon PowerShot A630 Digital Camera
Red lights on xbox 360
Which three lights? if its Top Left, Bottom Left, Bottom Right, then you have the infamous "Red Ring of Death." witch means general hardware failure. If you search around on the internet, there are some Xbox360 modding sites that sell kits to repair this kind of problem (if youre brave enough to tackle it).
Luckily Microsoft is aware of this problem and has extended thier warranty to 3yrs (but ONLY if you have this particular problem).
Otherwise you'd have to send it into Microsoft to get it repaired.
Apr 01, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
69 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
