Question about Poulan Pro Chain Saw 46cc 20"
I can't get the bar cover back on my Poulan mod. 2775 What is the
I can't get the bar cover back on. What is the trick?
    President:
  • 2,220 Answers
The chain brake is released. try this:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
It requires a fair amount of force. It usually makes a loud click when a keeper engages a detent. Just pull it slowly aft with a little grunt if need be at the rear extreme. HTH
Lou
If you need more help please reply below.
Posted on Feb 08, 2010
Poulan chainsaw oil leak
sounds like the small oil feed pipe inside oil tank as come away from the end. just push it back on you may need a pair of long snout pillers.. good luck
Nov 30, 2013 | Poulan Garden
I borrowed a friend's POULAN 14" ELECTRIC
Remove the side cover nuts and the cover, wind the bar adjuster screw fully back, it may be in the cover, or on the front of the saw, push the guide bar fully back toward the sprocket, loop the chain ocer the sprocket and lay it around the the guide bar, make sure the cutters on the top of the bar rail are facing away from the saw, this will make sure it is the correct way round make sure the bar adjuster pawl is engaged into the hole in the bar, if the adjuster pawl is in the cover, replace the cover making sure the pawl engages into the hole in the bar, refit the cover nur finger tight, adjust the adjuster screw so as the chain fits snug fully around the bar, loft the nose of the bar and fully tighten the cover nut, with a gloved hand pull the chain manualy around the bar to make sure it is fitting in the rails and the sprocket correctly.
Aug 31, 2011 | Poulan 14" Chainsaw
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
How do i get the side back on my poulan wildthing theres a ring on the cover does whats the trick on getting it back on does it go around the sprocket housing or inside it
That is the brake ring and should fit over the clutch outer drum. If the brake was set when you pulled the cover off, it will be necessary to release the brake mechanism to get it to pass over the drum. Good luck!
Sep 08, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Is there a replacement clutch cover for the Poulan PP4218AVX?
Hello Dave;
If a Poulan PP4218 your answer follows; if not post back with the correct model number and we can replace that too.
Poulan “PP4218AVX” IPL (exploded parts list)
We are going to replace this page 1; item 47
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2010/NIUS2010_545103408.pdf
Poulan “PP4218AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4218AVHD-Gas-Saw-Type-2/75.PP4218AVHD-Gas-Saw-Type-2.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 44; Clutch Cover Assembly; $9.50.
You also need;
• Item 43; Bar Mounting Nut; $0.56 each (need 2) and
• “Engine Assembly” print; Item 44; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
You will need retain the original model number IPL, there may be internal differences.
Down loadable PP218AVHD IPL
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2006/NIUS2006_545014325.pdf
Poulan “PP4218AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047503.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
May 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
JUST BOUGHT A 20'' POULAN PRO TENSION A CHAIN
the adjustment screw near the end of the bar( next to the engine) needs to be turned in to tighten the chain just don't tighten it to much
Apr 04, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 2775 20 inch chain saw. I can't get the cover back on all the way. I did take the cover off with the brake engaged. However, I realized that and re-set it before trying to replace the cover. I can...
Let me get this straight. You provided an inadequate description of your initial problem, Received a very good answer to your question as asked, rated the answer not helpful, but cannot quite figure out what is wrong and return for additional help. I forgive you.
Poulan 2775 IPL example.
http://www.ordertree.com/modelinfo/PWE/2775-Gas-Saw-Type-4/75.2775-Gas-Saw-Type-4.1.59.1.html
See the "Handle, Chassis & Bar Assembly" print for proper assembly. I suspect item 62 is on the wrong side of the bar. It should be on the engine side and if flared the flare goes toward the engine. The bar fits tightly against 62 and that is tight against the engine housing.
Item 65 fits in a cut out on the bar, I think you had that. HTH
Lou
You can change the rating given for the initial question. A few kind words are appreciated too.
Feb 09, 2010 | Poulan Garden
It requires a fair amount of force. It usually makes a loud click when a keeper engages a detent. Just pull it slowly aft with a little grunt if need be at the rear extreme. If you need any more help please reply below. HTH
Lou
Feb 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Chain Saw (Model 2775) Handle keeps coming loose.
If it keeps coming loose, you could try some thread-locking solution on the screw to keep it in place. The spring is there as an anti-vibration measure (well a vibration reducer) so the saw is more comfortable to use and so it doesn't cause excessive fatigue through constant, high vibration transmitted through to the handle. You could of course remove the spring if you wanted to but the saw is likely to be pretty uncomfortable to use. Without seeing the saw in person however, there must be some reason the screw keeps loosening... See if you can find that issue and replace the affected part, or try some threadlocker in the meantime.
Mar 16, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain falling off on small load
New bar and chain should do the trick. ONCE IT GETS A LITTLE DULL T BUILDS UP HEAT AND STRETCHES. Use a good quality case hardened chain they last longer and are well worth the extra money.
Jan 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
90 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
