Question about Refrigerators
My top freezer is not cooling the fridge below.
My freezer works okay, the "chute" which allows cool air to the fridge below is clear but my fridge is not getting cold.
  • 572 Answers
Check temp setting
Posted on Feb 08, 2010
LG 262SQA Model fridge cannot cool
That does not look like an LG model number, but regardless, it sounds like the defrost system is not working, allowing frost to build up and block air flow over the cooling coils in the freezer (where all the cooling for the entire refrigerator takes place). Take back panel off inside freezer, melt frost / ice with a hair blower. Test for continuity through defrost heater and replace if "open". If it was OK, problem could be deftost control, or as simple as a door not fully closed at some time, allowing excessive frost build up.
Nov 18, 2011 | LG Refrigerators
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Bottom fridge has stopped working. Top freezer is okay. Fridge light is working and thermostat is making operating noise, just no coolness.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Avanti FF510 (5.1 cu. ft.) Top Freezer...
Freezer compartment freezes okay to at least -5 degrees fridge will not cool below 17 degrees
Typically, the fridge gets its cool air via a vent from the freezer. If this vent becomes blocked, then the fridge won't cool. If there is nothing obvious blocking the vent (like a plastic bag) on either side then it is possible the vent is clogged with ice. To fix this, move your food to a cooler and unplug the fridge long enough for the ice to melt (12-24 hours).
Mar 03, 2011 | Refrigerators
NEFF K4663 fridge. the freezer works ok but refrigerator space does not go below 9deg C even at highest setting. have defrosted and water drain is clear.
The defrost board is not functioning properly.;
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Neff Refrigerators
Freezer has massive ice build up, refrigerator not cooling , no cold air thru chute
Possible that the auto defrost timer is not working and so the massive frost build up. This prevents the air to flow from vent to the fridge.
The auto frost must work on a determined setting of the timer cycle as the frost must clear so that the whole fridge is efficient.
So check the timerr which is normally placed in the rear bottom and is connected to the heater and is also inline with the thermostat.
Sep 26, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Why is there no cool air going into my refrigerator when freezer door is shut but works when freezer door is open
Good day,
All cooling comes from the freezer compartment. There is a supply vent connecting the top of the freezer to supply some cold air from the freezer thru the opening on the top connecting the freezer compartment to the fridge side.
As well there is a second opening or return chute located in the fresh food section on the bottom lower half, that allows air to return the air back to the freezer, completing the air flow cycle.In almost all cases, the return chute going from the fresh food section to the freezer compartment has become blocked.
Usually iced up.
It will ned to be completely defrosted. Many times, the return chute is difficult to see and in many cases almost impossible to defrost easily.
If you can see the blockage, then it can be defrosted with the gentle use of a hair dryer.
However, if too difficult to access, you may need to open both doors and leave the machine unplugged for an extended period, usually 12 to 24 hours.
I know it's a pain, but sometimes necessary. Many times, rushing a refrigerator repair is impossible.
The reaon it works when you open the doors is, you have given the machine a secondary source of air from the room.
Jun 29, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
