Question about Dell Dimension E521 (D10E16) PC Desktop
I am working on a dell dimension. after the dell screen the computer just goes black. i tried to do a repair install and now i can't boot to the cd anymore
  • p6singh May 11, 2010
    What version of windows is it?
It is media center edition 2005
Posted on Feb 08, 2010
  • advance1999 Feb 08, 2010
    it is windows media center edition 2005
When I boot my computer it goes to a black screen and says windows did not start sucessfully and then it freezes
To fix this problem I would suggest that you do a system recovery or reload the OS used on the computer.
You may need to purchase the windows installation CD or contact dell to find out their recovery procedures.
Jul 24, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
I can't change boot order Dell Dimension 3000
Hi Thanks for your question
Please try to use "Esc" button to access BIOS.
Good Luck
May 05, 2010 | Dell Dimension 3000 PC Desktop
After installing Vista SP2 update computer wont reboot from HDD or CD w/ vista CD
ok boot the computer and as soon as you see the black screen hit f1
or delete to enter bios go to boot menu and configure the cd-rom to be your first boot option. you can also hit f12 when you first see the black screen to enter boot menu. choose to boot from cd .
ok now install the disk and choose repair system .
Nov 13, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Dell dimension L800CXE I am trying to install xp home installed new hard drive changed boot sequence to cd first then hard drive goes to post screen the goes completely black and has the error insert boot...
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
Jun 11, 2009 | Dell Dimension 2300 PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Booting
Try removing the memory and the reinserting the memory. The problem sounds like you might have a bad motherboard, but I would try and remove the memory and fix it that way. Or you can get into bios F1 and see if it is recognizing your HD, or stick the installation disk in the computer and see if you can get anything to boot that way. If the computer boots from the CD replace the hard drive
Feb 10, 2009 | Dell Dimension 2400 PC Desktop
Dimension e 521 screen black
I reseated the memory module and the computer booted normally. Your suggestion worked, thank you.
Dec 17, 2008 | Dell Dimension E521 PC Desktop
Trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Oct 30, 2008 | Dell Dimension 4400 PC Desktop
I turn my computer off and back on i hear the music but i get a black screen
Try and do a XP repair: Boot the PC with a Win XP cd.
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 18, 2008 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Dell Dimension E521 (D10E16) PC Desktop Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
