Question about Microsoft Office Outlook 2007 for PC
When I send/receive messages in Outlook 2007 I get an error message "Out of memory or system resources" and no messages are sent or received. I am running Windows XP Pro
  • jimg531 Feb 08, 2010
    That is not true! I can develop an empty email, send from another machine and it sends fine but can not receive to the machine that gets the error message. If i develope an empty message and try to send from the problem machine I get the error message and the message does not send.It is not the size of message problem.
    President:
  • 1,197 Answers
Manually manage computer memory loadTOCNode(3, 'moreinformation'); When your computer's physically installed random-access memory (RAM) is running low, Windows adds available memory by using a paging file, generally known as virtual memory, on the hard disk to simulate physical RAM. By default, the virtual memory paging file that is created during installation is 1.5 times the physical RAM on your computer. Therefore, a computer that has 1GB of installed RAM will have 1.5GB of virtual memory.
You can manually change the size of the paging file to make it larger or smaller. You can also optimize virtual memory use by dividing the file space between multiple drives and by removing allocated space from slow or heavily accessed drives. To optimize your virtual memory space, divide it among as many physical hard drives as possible. When you select drives, follow these guidelines:
  • Try to avoid having a paging file on the same drive as the system files, usually drive C.
  • Avoid putting a paging file on a fault-tolerant drive such as a mirrored volume or a RAID-5 volume. Paging files do not require fault tolerance, and some fault-tolerant computers experience slow data writes because they write data to multiple locations.
  • Do not put multiple paging files on different partitions on the same physical disk drive.
How to manually change the size of the virtual memory paging file loadTOCNode(4, 'moreinformation'); You must be logged on as an administrator or as a member of the administrator’s group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
To manually change the size of virtual memory, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then press ENTER.
  2. Click the Advanced tab, and then under Performance click Settings.
  3. Click the Advanced tab, and then under Virtual memory click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
  6. Click OK to close the dialog box and apply changes.
Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
Notes
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
  • We strongly recommend that you do not disable or delete the paging file because this can lessen the computer's performance. However, if you decide to delete a paging file, set both the initial size and the maximum size to zero, or click No paging file.
How to manually optimize the memory usage loadTOCNode(4, 'moreinformation'); You can optimize your computer's memory usage to reflect your specific needs. If your computer is used as a workstation instead of as a server, you can increase performance by devoting more memory to your programs. Your programs will work faster and the system cache size will remain the default size that was included with Windows XP. Or, you can set aside more computer memory for a larger system cache if your computer is used primarily as a server, or if you use programs that require a large system cache.
  3. Click the Advanced tab, and then under Memory usage use one of the following methods:
    • Click Programs if you use your computer primarily as a workstation instead of as a server. This option allocates more memory to your programs.
    • Click System cache if your computer is used primarily as a server or if you use programs that use a large system cache.
  4. Click OK to save preferences and close the dialog box.
if none of the above methods of memory optimization works....
then your windows profile had somehow got corrupted. If you open outlook on any other profile on the computer set up your account and all your email in outlook should be fine. if this is the case... all that is left to do is save all your documents on a flash drive, delete the current profile and make a new one and put it all back
go to control panel, mail and make a new profile using a completely
new name. Add the old pst file to the new profile before opening Outlook. If you get errors when you try to add it, the backup process may have damaged the pst. Run scanpst on it and try to repair it or get another copy from the backup.
Regards
iversh
Posted on Feb 09, 2010
    Top Expert:
  • Microsoft Master
  • 76,164 Answers
All this means is that the number of bytes of information u are trying to send is in excess of what is allowed by the internet service provider u have, this is common with uncompressed picture or video files, always use JPEG, contact your internet service provider to find out about a larger allownace for your email.
Posted on Feb 08, 2010
Can't send emails in Outlook Express
Save yourself alot of headaches and use a web-mail service like Gmail.
Oct 27, 2014 | Microsoft Outlook Express
I have Outlook 2003 on Windows Vista. I continue to get Mailbox almost full messages, even when only one or two emails exist. Deleted, Junk, Sent, even Inbox are all emptied but after receiving 3 or 4
Check the setting for your quota. If that's small, you will get these errors all the time. Or, you can stop using Outlook.... There are other free e-mail systems.
Sep 11, 2014 | Computers & Internet
This message pops up when I try to receive email on microsoft outlook. Task 'pop3.telkomsa.net - Sending and Receiving' reported error (0x80042108) : 'Outlook is unable to connect to your incoming...
Probably your settings or configurations for Outlook is not properly set.
Refer to these sites for conguration settings using M/S outlook.
1. Configure outlook anywhere(MS Office 2010) @ http://technet.microsoft.com/en-us/library/cc179036.aspx
2. Configure outlook anywhere(MS Office 2007) pdf @ http://occs.odu.edu/projects/exchange/outlook_anywhere.pdf
Hope it helps.
Aug 23, 2010 | Microsoft Computers & Internet
I am useing Microsoft Outlook and keep getting a message when I try to send emails, Your outgoing smtp email server has reported an internal error if you contiune to receive this message contact your...
The problem is clearly indicated on the error code.
"the server responded 521 user is over the limit for messages to be sent in a single day."
Have you been sending a lot of messages using that account? From yahoo:
The limit for messages for yahoo is 100 per hour, max 500 per day.
If you believe that you are the one not doing this, you can either report this to yahoo or checked your Yahoo! account immediately. Change the security settings and most specially the passwords. It could be that your account is used as a spam bot.
Sep 22, 2009 | Yahoo Mail
Error message in Outlook 2007 0x8007000E...out of memory or system resources...won't send or receive..just get that message
You need to install more RAM in your PC. Google your PC model + the word RAM. You will be able to find more RAM and the information to install it.
Sep 22, 2009 | Microsoft Office 2007 Basic for PC
Need to delete email w/2 large of attachment after clicking send
1. Go the File menu, then choose Work Offline in order to stop Outlook from trying to send all mails:
2. Switch to the Outbox.
3. You now have two options:
a. Move the message: you can drag-and-drop or use the Edit: Move to Folder menu item to move the e-mail to your drafts folder. This will allow you to re-open the offending e-mail and slim it down by removing the large attachments before attempting to resend it.
b. Delete the message: this will immediately remove the message from the Outbox and put it in Deleted Items.
4.
If you receive an error at this point that says the message is being transmitted, close Outlook, wait for Outlook to exit (you may need to use Task Manager and wait for the Outlook.exe process to exit), and then start Outlook again and repeat steps 2-3. In some cases, the item may not be released until Outlook has restarted.
5. Go to the File menu, deselect Work Offline to start sending and receiving mail again.
Mar 20, 2009 | Microsoft Office Outlook 2007: Windows
Send/receive emails
delete your email settings and start over. If I am right, you just recently changed or setup this account..???
- make sure your using the most current settings.
GOOGLE - outlook settings for GMAIL or what ever provider your entering in. You may have had some issue at setup.
May 24, 2008 | T-Mobile Dash Smartphone
Outlook 2007
if the message had a file or picture in it sometimes you will have to zip it to compress it and secure it as it may be caused by the way the programme sends packets of information.
Oct 02, 2007 | Microsoft Office Standard for PC
Open Questions:
Microsoft Office Outlook 2007 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
