Question about Microsoft Xbox 360 Console
Xbox 360, 3-4 yrs old, suddenly no picture, only sound. Can you help advise how to fix it? TV (new, with HD, LED etc), says mode not supported, or No signal found, although connected. Sound comes through, but no video output.
    Genius:
  • 1,093 Answers
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Stop the heat to the scaler chip and you will have it working.
Posted on Feb 26, 2010
I'm not geting any picture or sound from either av or hd. tv says mode not supported. i thought it might be the av hd cable so i got a new one but still the same problem. it just stopped working last week...
this is just a suggestion but when i switched tv's one time i had a resolution issue, the tv i was playing on had a lower resolution than what my xbox was set at and would not play audio or video, to fix this start your xbox up and while its starting up hold down the "Y" button and the right trigger at the same time, it should revert your xbox back to the default settings, hope this could help
Mar 03, 2010 | Microsoft Xbox 360 Console
No sound or video on HD and TV modes
I would see if the cable is the issue. If not, you may have a nice new paperweight. Microsoft should fix this for $100 or you could buy a brand new one for $200.
I had this same issue with XBOX 360 #3.
May 13, 2009 | Microsoft Xbox 360 Console
No picture from my xbox 360 to my tv??
It is the solder under the GPU chip. Same as the 3 red light problem. YOu can send it to us if you want it fixed.
xbox360fixer@verizon.net
Thanks
Jan 03, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 will not send a picture signal to TV
sounds like you have a graphics card problem with the xbox 360. possibly loose/damaged electrical connections between the GPU and the motherboard which has caused the xbox to not display a picture. with this being a Hardware problem i would suggest calling the Xbox customer support, numbers can be found on http://www.xbox.com/support call up the support team and explain your problem.
I believe that microsoft will ask you to send the Xbox direct to them so they can fix the problem for you, it shouldnt take long to correct !
hope this helps
Oct 29, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Game mode on tv
If you have a HDTV then you need to change the resolution to 720i or 720p to support the XBox 360 HD video. If you have a standard TV (non-HD) then you'll need to change your XBox 360's video settings to non-HD. The problem sounds like your mixing up HD video signal. I really need more info about your TV. Is it HD? Or regular?
Mar 25, 2008 | Symphonic ST420FF 20" TV
HD Connections
try using the scart tht came with the xbox i had this prob first time but its quiet easy 2 fix
Dec 29, 2007 | Microsoft Xbox 360 Console
Samsung 40 inch lcd mode not supported
i have the same problem as well
wtf?
i used mine for ages then suddenly last night i looked all cell shaded and swirly so i left it over night. i turn it on this morning and get mode not supported. i thought it was my xbox but now i know it is the tv. thanks for at least that much. someone please help
Aug 17, 2007 | Samsung LN-S2651D 26 in. LCD Television
Microsoft Xbox 360 Console Logo
425 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
