Question about Storm by Central 3D103 Rotor Runout/Ball Joint Gauge Set
My storm 3d103 came without any instructions...where to get manual? Don't know if i even have all the parts
Panasonic microwave oven NN-5262SF. Totally dead after electrical storm. Plugged into live outlet. Even the light and fan dead. Believe a fuse in the oven but don't know where it is located. Can you...
Hi pdylhoff,
Try to replace the fuse using the instructions below. Replacing the fuse will determine if it's the cause of the problem.
1. Unplug your microwave. Remove the screws from the back panel. Take off the back panel.
2. Find the fuse. It should be near where the electrical cord comes into the microwave. The fuse is a small white bar with metal caps on either end.
3. Carefully remove the fuse. Avoid touching the transformer or other parts inside the microwave.
4. Take the old fuse into the store to find the exact match. You may also use the owners manual to find out what kind of fuse is used.
5. Replacing the fuse. Please put the cover back on and see if your microwave works. If it does, replace the screws. If it does not, try a different fuse. If the microwave still does not turn on, you may have to have it replaced by an authorized repairman.
Reminder: Please do not touch the transformer on the inside of the microwave. It can discharge enough electricity to cause harm or even death.
Hope it helps.
Thank you for using FixYa.
Jul 05, 2011 | Kitchen Ranges
The car started overheating. we put in a brand-new radiator less than a year ago, so we replaced the thermostat to see if that would fix it. the overheating issue has stopped, but we are still running a...
Hello, satania78 and thank you for asking your question on Fixya!
Here is a simple process that will walk you through a few steps that will pinpoint the overheating problem on your
2000 subaru legacy 2.5 ltr, without even using any tools. It has helped millions of people, and I am certain that it will help you, because I wrote it for people in your exact situation.
How to diagnose an overheating
1992 Geo Storm
Pay attention to the block test part of the instructions.
May 12, 2011 | 1992 Geo Storm
I want to unlock my Blackberry Storm 9530 ...do you know the codes i need
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry Storm 9530 and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry Storm 9530 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
Nov 23, 2010 | RIM BlackBerry Storm 9530 Smartphone
I have a moss car alarm ms705 but the remote is broken. do you know where can i find another remote for it pls?
Hello, I have the same security alarm moss MS705.
But without any manual or even box. And I don't know how to plug it in to my car. Can you may send me some pics of the wiring diagram from Instruction Manual? If you have one?
Thank you guys for any help.
Apr 09, 2010 | ' II' DIY Car Alarm Vehicle Anti-theft...
How do I unlock my blackberry storm (9530) without an unlock code?
Impossible, you only can unlock blackberry storm 9530 network with a blackberry unlock code. Remember my friend don't think to try untrusted code since if you put many wrong unlock code too many times, your phone will be hardlocked.
Dec 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to replace a heater core on a 93 geo storm possible diagram
try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 20, 2009 | 1993 Geo Storm
Unlocking my blackberry storm
It's a clear and fully detailed guide on how to unlock a BlackBerry Storm (95XX) :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
Mar 17, 2009 | RIM BlackBerry Storm 9530 Smartphone
My 5.8 AT&T 5.8GHz cordless phone stopped working after a storm
Try Googling (AT&T)(E5634B)(manual) without parens for instructions.
Jan 02, 2018 | AT&T E5634B Phone System w/ Caller ID
Storm by Central 3D103 Rotor Runout/Ball Joint Gauge Set Logo
Top Storm by Central Tools & Hardware - Others Experts
John Trevino
Are you a Storm by Central Tool and Hardware - Other Expert? Answer questions, earn points and help others
