Question about Electronics - Others
Can't formate a Sandisk micro sd hc
I bought a Sandisk micro sdhc 8Gb and a H'mc card reader (usable with sdhc), and when I try to read my card on my computer (an Acer with Vista), it says I need to format it. I do it and when it is almost finished, I got the message ''Windows was unable to format'', and when I give up, it tells me to check if it's well connected (it is) or if the card is locked (I haven't found any lock on my card).
Thanks if you find any clue, I'm bored to search...
  • miwaku_tpw Feb 08, 2010
    Thanks but it didn't work : it formated the card, but when I try to open it, it asks me to do it again...
    President:
  • 281 Answers
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 08, 2010
  • laikexpert
    laikexpert Feb 09, 2010
    Best to contact your dealer.
My computer wont format my micro sd card
Is it an SD card or a microSD card? If it's a 4GB (or larger) card then it's neither, but instead an SDHC or a microSDHC.
If the card is an SDHC/microSDHC then your card reader may be only SD-compatible. If this is the case then you can buy an SDHC-compatible card reader and use that. Alternatively, if you want to use this card with some other device, such as a camera or a phone, format the card in that device instead of in your computer.
Jul 10, 2012 | SanDisk 4gb Class 4 Sdhc Sd Hc Flash...
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
I bought an 4gig SD (HC)? card for my Camera. On start up, the Camera reads "FORMAT SET:OK" but when I select OK it Says CARD ERROR!. I've traded the "defective" one in for a...
The A402 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jan 15, 2011 | Samsung Digimax A402 Digital Camera
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
When i plug in my 8gb micro sd card my pc doesnt reconise it
is this a SDHC or some other type of high speed card ?
Does your SD reader accepts HC model ?
Have you tried a another SD Card ?
Regards
GeWiz.
Oct 17, 2009 | SanDisk 8GB microSDHC Memory Card with...
When i insert my 8 GB micro SD card it says the same thing.
Your 8GB card is considered "high capacity". You will need an SDHC USB card reader to read it.
Jun 24, 2009 | SanDisk 8GB microSDHC Memory Card with...
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
Dec 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Does the micro sd card been detected by your computer? If not, you may try other card reader, or other computer. If still does not detected, you may try to go to device manager and see whether the sd card is there, if yes, then you can assign a drive letter to the sd card.
Once SD card shows as a drive letter on PC, you can download sd card recovery software to get back your files. recommended asoftech photo recovery that helped me before. download it from link below
SD Card Recovery Software
You can refer to this card recovery tutorial
Recover files from SD Card
If above does not work, you may have to format the memory card (use quick format), and then use Asoftech Data Recovery to scan again the memory card and recover your files.
Dec 09, 2008 | SanDisk 4GB microSD High Capacity Memory...
Sandisk 4gb microSdhc wont read in computer
few computers nowadays read SDHC out of the box. you will need to purchase a SDHC reader that plugs into your USB port.
May 12, 2008 | SanDisk Cruzer Micro MP3 Player
Electronics - Others Logo
1,022 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
