Question about GPS
Hi, ive got a navman f100t and its stuck in usb mode when i plug it into the car.
  • 377 Answers
  • Try to download the latest firmware and if this doesn't work call the manufactureer if they can replace it for a cheaper price or if its still under warranty so that they can replace it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Posted on Feb 09, 2010
How to fix stuck on transfer screen
Hold down the on button until the screen goes black. wait two min, then turn it back on. If that doesn't work, try connecting your device to your computer and go online to the manufacture website. Most have a way to check your device and fix/update it.
Sep 01, 2014 | GPS
Nothing on screen except plug to computer
Your unit is in load mode. It is expecting an input signal from a usb port on a computer. If it is stuck in that mode, doing a master reset may help.
Nov 23, 2013 | Navman S30 Car GPS Receiver
I have a nav man f100t and it haz frozen with a girl in a car picture on the screen ,i cant turn if off,it just stays on the picture and only switches off if you flich the switch to reset.but it doesnt...
The only other option is to dis-connect B+ power to the GPS system for 60 seconds in hopes it will reset the processor, before you hook the power back up press and hold the reset button for at least 60 seconds to bleed off any residual charge, If all this fails you should consider a replacement unit.
Mar 04, 2011 | Navman GPS
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
How do I operate a navman F-series sv000266 canada
http://www.navman.com/in-car/europe/uk/Products/66739/68792/68791/
Apr 03, 2010 | Navman F20 GPS Receiver
Hi I am using Navman S30 car navigator. It has been giving me problems now. Every time I connect its charger, it turns on and gets stuck on the usb connection screen. I have changed its charger but I am...
Open your usb cable with a sharp knife; you'll find four different coloured cables inside: leave the red and black cable intact; cut the other two. Close your cable with some tape.
Your navman won't go into usb mode again, but it will charge your device
Dec 23, 2009 | Navman S30 Car GPS Receiver
Navman f20 will charge fron usb port on computer but not with in car charger
If it's not the original Navman usb loader then there's a easy solution to this : With a sharp knife carefully open the usb cable : you'll see four tiny cable's with different colours . You;ll have to cut two of those four cables ; Leave the black and red cable intact.
Use some tape to fix the cut in the usb cable. Now you can use your car charger and your navman won't go into usb mode.
Dec 08, 2009 | Navman F20 GPS Receiver
Sat nav froze
i turn on my gps on itz froze aint nothing comming up after
Jul 29, 2009 | GPS
When I try to update my navman It says I'm not connected and I am?
Hi - yes it probably is a driver thing. Navman's install software apparently doesn't install the Windows driver - you have to do it manually.
I just found this how-to page on Navman's website, and it worked for me:
http://www.support.navman-europe.com/FAQs/Drivers/F-Series/
Good luck
Peter
Aug 12, 2008 | Navman F20 GPS Receiver
Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
May 11, 2008 | Navman iCN 520 GPS Receiver
GPS Logo
309 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
