Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
The brush is not turning, looks like the belk is ok but don't know how to get to the belk
  • Dyson Master
  • 379 Answers
DC07s have two belts - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
Unfortuenately the belt that connects the motor to the clutch is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing your machine, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Posted on Feb 24, 2010
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes on my Hoover Steamvac Widepath LS SpinScrub model # F6040 900 are not spinning. What should I do to get the brushes spinning again?
On those models the brushes are turned by suction.
1. Check the lower tank to be sure its completely closed and sealed.
2. Check the lower tank to be sure the tools filler plate is in place (if you used the tools recently)
3. If both 1&2 ok, manually turn the brushes, if they do not turn freely you may have a stuck turbine or bad brush block.
4. Take the brush block out by releasing the tabs on each corner being careful not to break them.
5. Place a large flat blade screwdriver in the square drive hole that drives the brushes under the machine. Gently turn. It should turn slowly with some resistance. If it turns slowly it is ok. If it turns with no resistance it may be bad as well. If it will not you may be able to break it loose with some even pressure being careful not to strip the hole. If it will not turn or makes a lot of noise replace the Turbine assembly.
6. If the brush block has a broken drive shaft or will not turn replace the brush block.
Here is what that brush block should look like.
http://www.vacuummedic.com/product.php?id=206
Good Luck!
Aug 21, 2012 | Hoover SteamVac F5914-900 SpinScrub...
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
Have a bissell easy vac 3130-B and the brush on the bottom stopped turning i never looked before so i don really know if it turned in the first place
Behind the brush will be a metal thing that spins when the vacuum runs. That's what the belt loops over with the other end around the brush. You can sometimes find the belts a places like wal mart.
Aug 31, 2010 | Vacuums
The brushes and the belt are not rotating. The power seems fine and there is suction. I have no other history on this problem since I was given this almost new unit over Thanksgiving. Where should I be...
If you've got suction, but the brushes and belt are not rotating, then either the belt has come off the motor shaft, or the belt is broken and just looks OK.
Remove the bottom cover off the floor head and check that the brush roller turns freely. If it does, then check the belt.
Let me know if you need additional repair information.
Dec 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
No suction
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Sep 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka Uno brush not spinning
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
Mar 01, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
I have a self propelled Royal Dirt Devil vacuum model number 087900 and it goes backward fine but forward has to be pushed so hard it's impossible. Is this a switch? Do you know about how much the part...
You might try a new belt and/or brush roll. The brush roll is what helps pull a vacuum forward, the power drive helps, but if the brush isn't turning like it should, then it will hinder forward motion. The belt may look ok, but they stretch to the point that under load they won't drive the brush roll.
Feb 28, 2008 | Vacuums
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
46 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
