Have a Officejetpro 8500, Would like to know how to enlarge print>
  • 6,993 Answers
when you try to print any document, a dialogue box will pop out.
Look by the left side, you will see zoom. Under zoom you will see "scale to paper size. The default is "No scaling", change it to letter (It will be enlarged under letter).
Or click properties from the dialogue box, and change "paper option size" to Letter.
Letter will allow the work you print enlarge on the paper.
Take care
Posted on Feb 08, 2010
My OfficejetPro 8500 has just started making strange noises when printing. The noise sounds like guitar strings being strummed. It first occurs just after I have requested the print and before the print...
all printers start to make noises with the time , ill asure you that there is nothing rong with it others will tell you that you need to buy a new one that your will only last a few more months NO!! not true your good bro
Feb 01, 2013 | HP Officejet Pro 8500 Wireless All-In-One...
How do you enlarge copies on the hp 8500 printer
From The HP 8500 Manual
TIP:You can also use Fit to Page to enlarge a small photo to fit within the
printable area of a full-size page. In order to do this without changing the
proportions of the original or cropping the edges, the device might leave an uneven
amount of white space around the edges of the paper.
Oct 01, 2012 | HEWLETT-PACKARD 8500 Wireless All-In-One...
2 colors not working but have new cartrages.
Please check if u have print heads . If not run a nozzle clean & re- alignment , either on the printer menu or on maintenance through ur printing software
May 15, 2012 | HP PRT HP|OFFICEJETPRO K5400DTN INKJET...
Hp 8500 printer stuck in continuous cleaning and alignment loop after replacing cartridge
Printer wont do the alignment process if we replaced the cartridges, might be removed/re inserted the printer heads, then ply it process the alignment, if the print head nozzles are clogged, alignment process wont completes..
>Remove the print heads clean the nozzles with tissue paper gently at nozzles.
>borwse this link & see how to clean the print head,link:http://www.youtube.com/watch?v=ZAwYIbjswV0&feature=related
>Install the printer heads do the alignment..
> if not completed check which printer head clogged, replace the print head.
Oct 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How can i stalled memmory card in my Xperia X1
  • Determine what type of memory you need. This is the most important because there are so many types of laptop memory out there it can get quite confusing. RAM(random access memory) or temporary memory comes in many flavors. Rule of thumb, open the back of your lab top case to determine what kind you have and stick with it. Keep following and I will show you how.
  • 2 install-memory-laptop-1.2-120x120.jpg As stated above know your memory. Below is a list of the standard types of memory that are common amongst laptop pc' s.
    * DDR2 400 / PC2-3200
    * DDR2 533 / PC2-4200
    * DDR2 667 / PC2-5300 or PC2-5400
    * DDR2 800 / PC2-6400
    * DDR3 800 / PC3-6400
    * DDR3 1066 / PC3-8500
    * DDR3 1333 / PC3-10666
    Don't let the naming convention scare you. All you have to know is your memory type so your not trying to stick a square peg in a round hole.
  • 3 install-memory-laptop-1.3-120x120.jpg click to enlarge Determine how much memory you need. Generally its quite safe to either upgrade to 1 gigabyte of memory or 2. There is a sticker on the memory card that will tell you what type of memory you possess.
  • 4 install-memory-laptop-1.4-120x120.jpg click to enlarge On the back of your laptop, there should be a series of panels one of them depending on your model stores the hard drive and the other stores the RAM or memory. Use a screwdriver and unscrew the panel to gain access to the chips.
  • 5 install-memory-laptop-1.5-120x120.jpg click to enlarge Depending on your model, mines pushes in and then lifts up to release the memory chip from its bay. You would remove the memory and install the new memory in the slot. REMEMBER AS WITH ANYTHING DO NOT FORCE THINGS TO GO IN ANYTHING FORCED WILL EVENTUALLY BREAK THAT INCLUDES PEOPLE.
  • 6 install-memory-laptop-1.6-120x120.jpg click to enlarge Before you get all happy and such, CLICK ON START-->MY COMPUTER-->CONTROL PANEL-->PERFORMANCE AND MAINTENANCE-->SYSTEM. You should get a systems properties box that will tell you how much memory you have currently on your laptop. If nothing changed chances are you installed it wrong, purchased the wrong memory, or you recieved a defective product.
  • Oct 26, 2010 | Computers & Internet
    Copying from upper tray - line on the copy - good copy but has a solid thin line, about the size of the roller.. -- copying from glass is fine..--if it is the roller ! how do I clean upper roller and etc....
    hello, you said this was a copy, have you tried making copy from the glass, and not thru the doc feed, just to see if the output us the same. if not, open up the doc feed area, and clean the **** glass. now if your prints from the computer are the same as the copies, then its possible that the problem is pressure rollers above the ashpalt grey platten roller. alittle harder to clean but can be cleaned off.
    Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    HP Officejet Pro 8500 printer. How do I enlarge copy being printed on printer?
    no encuentro el manual de instrucciones de mi printer y desconozco como agrandar las copias
    jvp46@hotmail.com
    Sep 22, 2010 | Office Equipment & Supplies
    Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
    First print a self test page on the printer and check if you have black print on it or not.
    To do that Go to your printer :-
    Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
    If you have the self test page fine then try to make a black copy from the printer.
    Put a black font printout on the scanner glass facing downwards. Press copy black
    Check if you have the black ink working.
    If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
    If no then try to clean he ink cartridge and try to align the cartridge on the printer.
    To align Do this
    Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
    If you do not find the option in the tools option try looking for it in the print report...
    On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
    Now try printing..!
    Let me know if any of these steps works....
    May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    I need fax confirmation sheets printed when I fax from my HP Office Jet 8500. How do I get them to print?
    on the printer itself --> press the setup button--> use the arrow keys on the printer and move to print report option --> press ok when you select print report--> Find out fax confirmation option and press ok --> turn it on.
    If you do not find the Fax confirmation option under print report then find it under Tools option.
    Press setup on printer --> press arrow key on printer and finid tools --> under that try to find the fax confirmation option.
    once you switch on the fax confirmation option on the printer. every time you send a fax you will receive a fax confirmation also.
    May 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    HP OfficeJetPro K8600 is printing blank lines on the
    needs cartridge? or could try cleaning the heads.
    Dec 04, 2009 | HP OfficeJet Pro K8600 Printer
    18 people viewed this question
    k24674
    jasbo
    jasbo
