I have an old hp desktop 8570c. I tried using a product called a ''Tornado'' to transfer files to another computer. It didn't work. Now when I plug in my computer (hp 8570C), it simply runs with the busy light on. Hooking it up to a monitor gives me only a black screen. I've tried using the keyboard functions but can't get anything on the screen. The computer will not hard shut down by holding the button and simply unplugging it and plugging it back in gives me the same result...running but with the busy light on, nothing but a black screen, and no way to shut down. I have info that I need to retrieve from this computer. Do I need to go into the computer itself and try something? Please note...I was given a solution through this site where it was suggested to hold in the ''on'' button while hitting the F10 key. It did not work. Remember I have only just a black screen. Does anyone have any other suggestions? Is there any way to shut by actually opening up the computer?
  • joecoolvette
    joecoolvette May 11, 2010
    I concur with what jasonmteat stated, and would like to offer additional information to support his solution. Example of an economical external enclosure,http://www.tigerdirect.com/applications/... (Not an advertisement for said product nor website) This is HP Support, and the main menu for the HP Pavilion 8570c Desktop PC,http://h10025.www1.hp.com/ewfrf/wc/produ... Here you will find out how to open the computer case, and remove/install a Harddrive, ( How to, Adding/Replacing Hardware, Replacing the Hard Drive) If you do not have the Restoration CD Disk, you can obtain one from HP Support. (Contact HP. Phone number is 1-800-474-6836. Give the nice person on the phone your Model Name, and Model Number - Pavilion 8570c, and the Serial Number. This is on the back of your desktop computer, next to the Windows Product Key. It is in the white Service Tag. The restoration disk is free. The Shipping and Handling is not. $17 for a 5 to 7 day ship, $24.95 for a 2 to 3 day ship)
  • 78 Answers
You can open the CPU and shut down by removing and shorting the wires in the mother board ... wen u open it (cpu) ,u find wires runnnig frm led to ur mother board (some 2 pin connectors ,generally its written on the wires ).....unplug dat wire carefully and short dose 2 pins .....i hope m clear enough ...contact me on my id ajaymishraait@yahoo.com
Posted on Feb 09, 2010
  • 111 Answers
If I were you I would remove the HDD from the computer and place it in an external enclosure, and then connect it via usb to another computer. This will allow you to retrieve the info you need. As for getting that computer back up and running, once you remove the files you need replace the HDD back into the system and reformat using the recovery CD's
Posted on Feb 08, 2010
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
Synching Itunes
To Transferring Playlists
If you want not only your content but also your playlists to exist on your new computer, you will want to transfer a copy of all your playlists from your old computer. To do this, choose File > Library > Export Library on your old computer. Save the XML file that is created to your desktop.
Send the playlists file to yourself as an e-mail attachment, use an external drive, or use file sharing to move the playlists file to your new computer. Once the file is on your new computer, open iTunes and choose File > Library > Import Playlist. The import process will remove any items from the playlists that you didn't share via Home Sharing.
Source:http://support.apple.com/kb/HT4527
Alternative Method: http://helpmerick.com/how-to-transfer-your-itunes-library-playlists-to-a-new-computer.htm
Dec 02, 2011 | Apple iTunes
How to download my file from my old computer
The simplest way to transfer files from your old to your new computer is by using USB flash drives. Just save your files from the old computer onto the flash drive then plug this USB drive in to the new computer and save the files there. If you have large files, you can also use an external hard drive to copy and transfer files.
Mar 22, 2011 | Computers & Internet
How to transfer files from my old HP Pavilion 8650C to Dell computer or seagate external hard drive?
With the drive plugged in, open My Computer. You should see an icon labeled something or another that relates to your external hard drive. If you cannot determine which it is, unplug the hard drive. One of the icons should vanish. When you plug it back in, open the drive that appears. In order to transfer files, simply find the ones which you wish to move on your computer (most likely in the My Documents folder), then copy and paste them into the hard drive. Tell me if you have any more issues, and vote if this helped!
Oct 10, 2010 | HP Pavilion 8650C PC Desktop
I have an old hp desktop 8570c. I tried using a product called a "Tornado" to transfer files to another computer. It didn't work. Now when I plug in my computer (hp 8570C), it simply runs with the busy...
please press the start button and after that press F10 key for boot in to safe mode, after your pc will me boot in safe mode at that time u"ll remove your "Tornado" from add remove programms.
Feb 02, 2010 | Computers & Internet
Transfer all files from my old desktop to new laptop
you can do that by following the steps below;
Instructions
  1. Step 1 Connect your laptop to your desktop through a home network connection. If you have a home network, you can hook up your laptop to it via an Ethernet cable or a wireless network card. Then, you can set a folder on your desktop computer to be shared across the network. To set a folder as shared in Windows, simply right click on it, select "Sharing and security," select the "Share" tab and check the box labeled "Share this folder on the network." You will then be able to access this folder from your laptop and transfer files to your.hard drive.
  2. Step 2 Purchase a USB jump drive. These handy devices are the size of a key but can store five gigabytes of files or even more, depending on the type of USB jump drive you buy. Insert the USB jump drive into your USB port and your operating system should find it as new hardware. If a window doesn't automatically come up, you can find in your drives under "My Computer." Then, you can click and drag files into it, remove the drive and take it to your desktop computer and access the files there.
  3. Step 3 Put your files onto another external storage device, such a CD, floppy disk or external hard drive. Files are transferable between any computers as long as you can store them on something external, then use that external device to move them to the other computer.
  4. Step 4 Email files to yourself. If you only have a few files that you would like to transfer and don't have any of the equipment used in Steps 1 through 3, send yourself an email with the files attached, access your email from the other computer and download the files to your hard drive.
Sep 10, 2009 | Dell Computers & Internet
Transfer XP files to Vista: i am having a nightmare of a time trying to transfer files from my XP computer to my new Vista computer. I tried using an Easy Transfer Cable fo Windows Vista. The driver CD was...
yeah u can use remote desktop connection.which u can find in start->program->accessories->remote desktop.first u need to connect the two computers using lan wire(ethernet cable)....for detailed help ask me on satvir_kambo@yahoo.com
Sep 01, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Does Belkin transfer programme files?. Also I want to know if this product transfers from XP to XP, desktop to desktop. Basically, I am moving from a 20gb to 80gb hard drive and want everything to be in...
A transfer cable kit will only transfer files and settings to another computer. What you want to do is have your 20GB hard drive imaged to a clean 80GB hard drive. That would transfer everything and give you extra space.
Some people call this "Ghosting" using a product from symantec called "Ghost" and another product that can be used for free (home use) would be "Drive Image XML" .
I would suggest going to your local Computer Shop and requesting this type of service.
Mar 13, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Product key won't work when I moved the program to different computer
usually the ONLY solution for this is to call MS (if its a MS program) and get a New Key.. Usually, what happens is there are limits for installation of MS Products, but if its your product and you have the orginal key, they will give you a new one that will activate the program. So keep that 'old' key, b/c you need it to give it to them when you call.
I also try to install MS Office on another computer once my old one crash and I hath to buy another one.. once trying to install the MS software on this computer it kept coming bck 'invalid" Product Key, and had to call MS to get a new one.. So try that, and I'm sure that shuld solve your problem and allow you to gain access bk to your product.
GL!! 'imhere2helpu'
Oct 26, 2008 | HP rp5700 Business Desktop PC - RT981UTABA
I am trying to transfer files from an HP with Windows 95 to my HP Laptop with Windows Vista. My old computer tells me that I do not have the proper driver installed. What to I need to do to install a...
You cant transfer files from your old computer with Win 95 Using windows easy transfer which is a file transfer software in vista . If you want to transfer files then you have to copy them on a cd or dvd then paste them to your new computer . It will take a lot of time . Call a computer expert and tell him that you want to transfer the file from your old computer . He will do that easily .
Please rate me .
May 14, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
