Question about Dell Dimension E521 (D10E16) PC Desktop
Dell Dimension e521 screen goes blank after post.
When i try to boot up this computer i get the dell screen then it goes black. I could boot to a cd rom and tried to do a repair install Xp media center but the computer needed to reboot during the repair install. Since then i cannot boot to the cd-rom even?
  • 542 Answers
Follow the steps mentioned below:
1st Step: Check that whether the HDD is been detected in the BIOS Mode. Also check whether the boot device has been selected properly in BIOS mode.
Still you are facing problem, then
2nd Step: Incert the XP CD and try to repair the same once again.
Also check for BAD sectors in the HDD. for this you need to connect the HDD to other system and run scandisk or chkdsk /f in command line.
Revert back for more assistance. Also give your valuable feedback/rating for the solution provided.
Posted on Feb 08, 2010
How do i reformat my dell dimension e521 computer
The easiest way is to boot from the Windows installation CD and select format hard drive.
Jan 17, 2012 | Dell Dimension E521 PC Desktop
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Help! My dell dimension E521 will not boot after
Its seems like your RAM is not working properly, so once you replace the this RAM and check it, you problem should be resolve.
Regards
Ashly
Feb 01, 2010 | Dell Dimension E521 PC Desktop
After installing Vista SP2 update computer wont reboot from HDD or CD w/ vista CD
ok boot the computer and as soon as you see the black screen hit f1
or delete to enter bios go to boot menu and configure the cd-rom to be your first boot option. you can also hit f12 when you first see the black screen to enter boot menu. choose to boot from cd .
ok now install the disk and choose repair system .
Nov 13, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Need factory setting
If your computer came with Restore CD's then boot to the CD and follow the onscreen prompts.
If you have a restore partiton Reboot the computer and press ALT +F11 at the Dell Boot Spash Screen. Follow the onscreen prompts.
Mar 30, 2009 | Dell Dimension E521 PC Desktop
Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Mar 15, 2009 | Dell Dimension E521 PC Desktop
Dimension e 521 screen black
I reseated the memory module and the computer booted normally. Your suggestion worked, thank you.
Dec 17, 2008 | Dell Dimension E521 PC Desktop
Dell Dimension E521 (D10E16) PC Desktop Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
