Question about Copystar CS-1500 Copier
Need replacement part that holds the left rear of the lid so the lid will lift & stay
    President:
  • 3,085 Answers
What you need is a left hinge assy, $65.00, but only sold by authorized Copystar or Kyocera Dealers
Posted on Feb 08, 2010
How do I get rid of paper jam that stays on even if nothing jammed
My guess is that there is a piece of paper somewhere blocking a light beam or in a contact switch.
Try a little air if you can't manually feed a sheet of paper. Use the heaviest bond you have.
Jan 06, 2015 | Canon Office Equipment & Supplies
How do you remove inner tub to get to the outer tub of Fisher & Paykel gwl11
You need 2 people for this.. Unscrew plastic wingnut down the centre of the agitator.(2) undo 2 phillips head screws under little rubber covers just under lid at front top edge.(3)lift top of machine like a car bonnet,get someone to hold it up for you.(4)Unclip big round plastic ring on top of the bowl,you may find its attached with a spring at the front left hand corner,just lay the plastic ring over front of machine & let it hang.The bowl should just lift straight out.Be carefull,the outside of the metal bowl is like a cheese greater trust me! PS when you put it back together & you lower the top of the machine(make sure that little white plastic lever hanging down) the right hand rear go's outside the righthand rear of the tub NOT squashed on top.Its an out of balance lever & it needs to dangle outside of the bowl/tub right rear.GOOD LUCK!
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Cabrio WTW6600SW0. I need to replace the lid but ...
do you see about 2-4 inches down a crease that runs all the way around the top?
there are 2 clips in the front you need to push in with a putty knife and lift the whole top up.
if you where to look at the very left corner and go about 5-6 inches in you will find the clips.
can be a pain.
make sure when you do lift the whole top that you hold the lid or it will crash into something.
let me know if this helps
May 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The Switch, Lid on my Kenmore washer/dryer combo broke, and I need to lift up the washer console to replace the switch, lid - does anyone know how to lift up the console on the combo?
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Kenmore Washing Machines
Need to replace left directional bulb
I believe there is a small panel inside the rear of van,in that corner that comes off. You may have to lift lid on storage lid back there to see it. Clips on there if I remember correctly, if not let me know.
Apr 06, 2009 | 1996 Plymouth Voyager
New lid switch needed?
lid removal ? may i suggest you first remove the rear panel then you may find the top panel was held in place by the top securing screws holding rear panel ? you may have to slide top panel rearwards a little to clear from front then lift off ? careful of wires to plug/switch hope this helps ?
Oct 19, 2008 | Kenmore 22422 Top Load Washer
ESTATE WASHER
ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing lid..no click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer spins after lifting lid several times
I would bet you have a lid switch starting to go bad. This is a common symptom. This is an inexpensive and simple repair job if you wish to pursue this on your own. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
Some washers have the lid switch under the right-hand side of the wash tub opening and is activated through a small slot on the wash tub casing rim by a small plastic piece on the lid called a lid strike. If this is the type you have, make sure the lid strike is still intact or the switch will not activate. Check the two mounting screws next to the slot and make sure they are present and tight. These are the mounting screws that hold the lid switch in place. If they come loose it can prevent the switch from activating.
Newer models have the lid switch mounted under the washer casing in the left-hand rear adjacent to the left washer lid hinge. The switch is activated by a rod on the lid hinge. Sometimes a simple adjustment of this rod can correct contact problems.
If you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Let me know if you require further assistance or part sources. I hope this helps you.
Jul 07, 2008 | Washing Machines
WTW5800SW, safety switch needs replacing. How do I do it?
  1. Before replacing the switch check the lid hinge screws on the left side, if they come loose the switch will not activate.
  2. As part of the lid hinge, there is a rod under the cabinet on the left side that can be bent upward by holding the lid open and pushing on the rod.
  3. To replace the switch, insert a putty knife under each corner, push to release a latch. With console lifted, the switch is snapped into the cabinet on the left side.
Jun 23, 2008 | Whirlpool Washing Machines
Washer repair
on rear of console remove the 2 screws 1 on each corner..console lifts and rolls backif switch on right under lid remove clips on each side cabinet then lifts from back to front and lifts off if switch ic under left side of lid at rear make sure hinge scres are tight on left hinge and lid hinge is striking switch solid if not push hinge at curved section toward back of washer
Jun 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Copystar CS-1500 Copier Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Scott Yeoman
Level 1 Expert
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
