Question about Car Audio & Video
I have a SPX 2 channel high performance amplifier i can not get power to it what could the problem be?
  • 63 Answers
Could be a blown fuse or your ground got disconnected. Check all your connections and make sure everything is tight
Posted on Mar 06, 2010
Why is my Jensen SPX-17 home entertainment subwoofer only putting out about 10% functioning base power volume level and loudness?
Gary, If you have the subwoofer open, what did you keep from measuring the voltage of both power supplies? And while measuring, why not put a load on both, and see what current they can handle?
When the error moves with one component (power supply) the error must be there. Without a multimeter, (I have several, but I'm not close to the power supplies) you can't tell if the power supply is working to full performance. So start there.
Just try to find out, if a part of the rectifier is defect (one diode) It won't be possible to point out what is wrong, if you can't measure on the device yourself.
Sorry.
Nov 23, 2014 | Audio Players & Recorders
Whats rms on legacy la1490
http://en.wikipedia.org/wiki/Root_mean_square
In mathematics, the root mean square (abbreviated RMS or rms), also known as the quadratic mean, is a statistical measure of the magnitude of a varying quantity. It is especially useful when variates are positive and negative, e.g., sinusoids.
However, the term "RMS power" is sometimes used in the audio industry as a synonym for "mean power" or "average power". For a discussion of audio power measurements and their shortcomings, see Audio power.
http://en.wikipedia.org/wiki/Audio_power
Oct 13, 2009 | Legend LA1490 - American Legacy Series 2 -...
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Aug 14, 2008 | Car Audio & Video
Car Audio & Video Logo
242 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
