Question about Dell E173FP 17" LCD Monitor
No power, won't turn on. same problem with 5 of them. e171fpb
  • Dell Master
  • 1,684 Answers
The E171FPb power board has 6 capacitors that will need to be replaced. I am not at our office right now so I don't have all of the rating for the parts but if you email me at tech@ccl-la.com I will send it to you as soon as I get back in.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Feb 08, 2010
Dell monster power button flashes green
This would seem to suggest a lack of power from the PC. Check the cable from the graphics adapter (usually blue if VGA) and the connection to the monitor itself.
Sep 22, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
Green light won't come on
Hi Good day!! Try to check the power cable. replace the power cable and then try to turn it on.
Nov 18, 2010 | Dell E171FPb 17" TFT LCD Flat Panel...
The screen goes black how can I fix this
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board: http://www.lcdrepair.us/e171fpb-power.html
http://www.lcdrepair.us/e171fpb-inverter.html
May 12, 2010 | Dell E171FPb 17" Flat Panel LCD Monitor
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
No power
Did you find out what was wrong with your monitor?
Dec 09, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
No picture
Try to reverse the cable....use the end connected to the computer at the monitor and the monitor end to the computer. If tapping the monitor doesn't do anything and tapping the cable at the computer does the same faults then I would have it checked or just replace that cable.. Good luck.
Dec 02, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Sep 04, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
157 people viewed this question
Alun Cox
