Question about Vacuums
How to change belt on Panasonic MC-E464 vacuum cleaner
Have no handbook to guide, please explain how to change belt on this vacuum cleaner.
  • Zac2007 Feb 23, 2008
    To do this have to remove brush and can't see how to do this. Can you help here? Thanks!
    President:
  • 1,673 Answers
Remove the bottom plate, the belt goes fron the brush rol to the motor shaft or pulley.
Posted on Feb 23, 2008
  • Lauren Junge
    Lauren Junge Feb 23, 2008
    On the bottom, there either screws to remove, or a slide to push to release, but you have to remove the bottom plate to be able to access the brushroll and belt. The brush roll is probably in slots on each side, use a flat blade screwdriver and pry the end back enough to so you can pull up on the brush roll to take it out.
How to change the belt
usually reading the directions helps .
Jul 27, 2015 | Kenmore 6 Canister Type C Sears Vacuum...
Panasonic optiflow upright vaccum
Hello, Put the vac on its side and remove the screws holding the cover plate on. This exposes the beater bar and belt on the side. Pull the beater bar out and take the belt off. Reverse this to put the belt back in place.
May 30, 2014 | Panasonic MC-UG323 OptiFlow Upright Vacuum...
Need owner's manual for Panasonic MC-9420 canister vacuum cleaner
goto> http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Vacuum-Cleaners/Canister-Vacuums/model.MC-3920
Feb 21, 2010 | Panasonic Vacuums
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
What belt does the Panasonic MC-V7380 Vacuum take?
Here is a link to the belts you need for your model and the manual which has instructions:
Panasonic MC-V7380 Belts and Manual
Dec 12, 2009 | Panasonic MC-V7380 Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Belt drive
http://www.partstore.com/Model/Matsushita/Panasonic/MCV7395.aspx?SearchTerm=True
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Panasonic vacuum cleaner MC E554
Wish you had listed your model number, they are all different you know, that wire you refer to I have seen on some models and it is only a belt guide. Should be a slot that it fits into.
Feb 23, 2008 | Vacuums
Vacuums Logo
658 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
