Question about Traxxas T Maxx 3.3 Monster Truck
My stuck on a nutrol and it wont move but it works
    Problem Solver:
  • 13 Answers
I've seen a few problems with this being the transmission. usually broken teeth in the tranny. you didn't give much detail, but from what you described, that's about the best advice i can give.
Posted on Mar 17, 2010
Truck runs but when put in gear it dies I put new wires distributed and cap and safety nutrol sensor and new gas filter please any one can you help me it's a 1995 gmc 5.7
Common on Gm vehicles is the TCC (Torque Converter Solenoid) can cause converter to lock up and not allow it to stay running or it could be the IAC(Idle Control Valve). The valve gets stuck open and when shifting from either park or neutral it doesn't send a signal to computer to bump up idle so the vehicle stalls. Hope this helps.
Sep 14, 2014 | Cars & Trucks
2009 sonta wont go into park
the shifter wont move, or moves to park but park does not work?
try to be clear.
are you on flat ground?
are you against a curb
did you wiggle the steering and turn the key and wiggle the shifter to park? at once.
there is thing called park lock out but works moving from P/N to gears active, R/D/L. usually going to N/P is no problem. unless cables are rusty.
Jun 15, 2014 | 2009 Hyundai Sonata
Stuck float
The float is stuck, how? do you mean you cannot pull the little hinge pin out OR the float wont move up or down? If the float wont move up or down then; Your float is stuck because the needle valve is stuck in the Seat area. Spray carburetor cleaner in that area and slowly try to work the needle valve up and down. It should free up very soon and the needle valve and float will come down and out.
Jul 23, 2013 | Garden
My crysler 300 - C is stuck in park and wont let shifter move i move the pink pin under shifter plate left and right and still wont shift
This car uses a park lock system, it is operated by the brake light circuit, so is if the brake lights are not on when the pedal is pushed the park lock will not released. if the brake lights do work you have other more serious issues **** as a defective lock solenoid. The owners manual gives the bypass procedure around this problem, check the index.
Sep 27, 2012 | Cars & Trucks
It's hard to explain, but i will in the best way i can. . . One morning when i started my car, i tried to press the gear thing in but it was stuck, so i kept trying and it finally went in. And once I...
Okay, you are correct, the key is stuck because of the shifter lock wont release, the most common reason is its stuck, you will need to remove the covering around shift to get to shifter lock release solenoid, there you will clean and lube it, you will need to move it by hand as you spray wd40 on the arms, you will see how it work by pressing the shift release and you will see to lever that gets pushed, it wont move because its stuck but you will see the levers move inside, hope this helps, good day.
Sep 03, 2011 | 1999 Mazda Millenia
I have a four door ford escort and my problem is when I stop at a red light my car turns off unless i put it on nutrol then it wont turn off . how do i fix my car for it not to turn off during stops in...
Hi, the likely problem is either a vacuum leak or a faulty idle air control valve. Please see my tip at http://www.fixya.com/cars/r7427423-fix_poor_idle_high_idle_stalling_fuel . These are generic instructions. If you getstuck or need specific instructions for your car, please get back to me with model, year and engine info.
May 27, 2011 | 1993 Ford Escort 4 Door
I have one windshield wiper working on a 1995 nissan altima whats the problem the other moves a little bit but wont go all the way across
As you say the other one moves a bit the linkage appears to be connected, check the nut for tightness on the arm that wont move, they sometimes come loose during frosty periods when the wipers are stuck to the screen.
Regards
Steve.
Mar 20, 2011 | Nissan Altima Cars & Trucks
Car dies when at a stop unless i give it gas or put it in nutroll
clean the idle air controller and check for vacuum leaks
Sep 29, 2010 | 1996 Kia Sportage
Ipod nano silver
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Jan 13, 2008 | Apple iPod nano
Traxxas T Maxx 3.3 Monster Truck Logo
319 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
