Question about Lanier Office Equipment & Supplies
My Lanier LD015spf is indicating I should replace the photoconductor (this has been the case for almost a year now) and through much research I have found a replacement part # 411844. What I cannot find is any sort of instruction manual or other documentation on ''how'' to replace this. Can I do it myself or will I need to have a service tech install it? And if I need someone else to do it, where would I find someone in the Portland, OR area?
  • 10 Answers
SOURCE: Copier will not sort documents correctly
Hi songman to sort you need to have the A4 paper in both cassettes one cassette needs to be A4 portrait(wide edge first) and the other needs to be landscape (short edge first)make sure you have the green paper size selector set correctly as well regards Dr Bob1
Posted on Apr 10, 2007
NALDZ
  • 38 Answers
if you are using a4 size paper,,,make sure that your using tray is prograo to a4 size...look the color green in tray with a number indicated there and adjust this that you want to use paper size
Posted on Jul 07, 2007
  • 7 Answers
SOURCE: photoconductor defective
Solution #1 above is WRONG. I suspect it was written by an epson consumables sales rep.
The photo conductor has a Kill chip that disables the PCU after a shamefully short number of copies. This chip can be replaced for about 30 pounds sterling. Google for it.
You can get a considerable extension in the use of the PCU, but it will have to be replaced at some point.
I even had the blue roller refurbed by Total Image Direct near London, UK. That was also about 30 quid.
I'm on my 3rd or 4th set of catridges (took over a year before people would produce refills for them though) and still on the first Photo conductor.
Posted on Mar 24, 2008
hquiteculo
  • 19 Answers
SOURCE: Canon NP6025 Service/Repair Help
yes I can go there for to see , but I need to now whats this machine have
Posted on Feb 11, 2009
SOURCE: Lanier LD225 Drum Reset
There is a small "flag gear" on the back that needs to be in the "up" position to contact the button on machine and initiate it when it is installed
Posted on Feb 19, 2009
Hi yes i have a Lanier LD015f. I just received the photoconductor. Hoow do you replace it?.
Hi, you should have received instructions with the photoconductor, but replacing it is pretty straightforward.
To remove the old photoconductor:
- Open the front door and the right side door. - Remove the toner hopper. - Unplug the connector going from the photoconductor into the machine. - Pull out the photoconductor.
To install the new photoconductor:
- Remove all of the tape, paper, and packing materials. - Slide the photoconductor into the slot left empty by the old one. - Attach the connector and route it behind the plastic guide. - Reinstall the toner hopper. - Close the right side door and front door.
If the machine was on when you replaced the photoconductor, it should automatically detect the new one.
Dec 01, 2010 | Lanier UNKNOWN
How do you enlarge copies using a Lanier LD015spf
The option for enlarging copies on any printer are usually found under the "properties", or, "preference" tab/button. There should be sub-tab that says "scaling" that is defaulted at 100 percent. Increasing that number enlarges the copy.
Hope this helps. :)
Oct 02, 2010 | Lanier Office Equipment & Supplies
It show 84 replace photoconductor
84 replace photoconductor on the display indicates that the photoconductor has reached its expected life rating. You may continue to print but will be at risk for developing print quality issues. It is recommended that photoconductor unit be replaced. After replacing a photoconductor unit, you will also need to manually reset the PC counter, Thanks
Sep 22, 2010 | Lexmark Lemark E352DN Laser Printer
Erase replace photoconductor message for lanier ld015
Its cheaper to replace it. If you reset the unit in a short period of time it will lock up with used toner. Once this happens you still will have to replace the PCU plus the added cotst of the damaged gears and extra labor.
Oct 14, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Paper is jamming
When you say startup, do you mean when you turn the machine on or when you attempt to print?
For the first, check to see if there isn't any small piece of paper stuck anywhere in the paper path. for the second condition, clean off the feed roller with a piece of cloth dampened with alcohol.
Jul 26, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Our lanier machine (LD015f) keeps flashing replace
Open front and right door, remove toner, un plug photoconductor release photoconductor tab on upper left of it, new "PCU" will auto adjust, sold as a supply. Hope this helps. Carl
Jul 10, 2009 | Lanier UNKNOWN
LANIER 5515 ERROR CODE SC390
the problem is with the toner density sensor.a quick fix would be to replace the photoconductor unit.thereafter you need to do the developer initialization adjustment.
Jun 09, 2009 | Office Equipment & Supplies
How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
May 25, 2009 | Lanier Office Equipment & Supplies
Black spots on printer
Most Likely the PCU (photoconductor) needs replacing, but it could be a fuser roller problem. It's impossible to say for sure without seeing it.
Apr 27, 2009 | Office Equipment & Supplies
Feb 19, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
350 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
