Question about Mitsubishi DD-6040 DVD Player
My dvd player is dead; not turning on or responding to any button pressing or cable fixing. But I was watching a movie when it died. How do I get the dvd out without destroying the dvd player?
SOURCE: DVD works, but no cable
YOU CAN EITHER SWITCH YOUR CABLES ARE CALL UR CABLE PROVIDER AND IF U HAVE SATTELITE THAN IT COULD MOST LIKELY BE UR CABLE ON THE REAR OF UR HOUSE WHERE UR BOX IS ARE THE CABLE IN SIDE THE DISH. MAYBE EVEN U DIDNT SWITCH THE LINE BACK TO CABLE TRY SOME OF THESE THINGS THEN U CAN SEND ANOTHER MESSAGE IF IT WORKS ARE NOT LETTING US KNOW WAT HAPPENED THANK U
Posted on Dec 10, 2007
  • 7 Answers
SOURCE: DVD player
Clean the pickup using a commercial cleaner disc.That's the only quick,cheap fix.
Posted on Mar 11, 2008
  • 13433 Answers
SOURCE: DVD/CD Drive is not responding. Model Inspiron 1420
right click my computer, select manage, then on the left side find device manager.
in the device manager find your cd drive and see if it has a error code
if there is a error code then here is a fix i made long time go for few error codes
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Posted on Jul 20, 2008
SOURCE: How can I watch a movie without a remote
Maybe the Play button?
Posted on May 08, 2009
jomabug76
  • 1148 Answers
SOURCE: How do I connect cables for Sony Trinitron Dolby Digital SDTV, Emerson VHS/DVD Combo, HD DTA1080 Converter Box. I've tried all the diagrams that came with all systems and none work. I should add that
HOOK THEM UP SEPARTLY,,,DVD COMBO WITH RCA JACKS
Posted on May 15, 2009
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
How do I program an apex ad 1110wm DVD player with a RCA universal remote?
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR,DVDor Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Sep 16, 2011 | Apex Digital AD-1110W DVD Player
What chanel do i put tv on to watch dvd movies
You are trying to work out how to watch a DVD movie on your TV
The DVD should be connected to your TV with Audio Video cables.
And it will most likely be connected to AV1 on your TV
The easiest way to find out would be to
  • Put a DVD in the Player and press play
  • Now the TV is probably in channel mode, so find the button on the TV remote that says TV/AV
  • now press this button TV/AV and it will scroll from TV channel to AV1, AV2 etc until you see the DVD picture.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | GPX D1816 DVD Player
It does'nt turn on don't respond any comand The
I had a problem similar to this. I fixed it by toggling through the top buttons on the remote control. Sometimes the wrong button gets pressed and the remote cannotcontrol the unit it is supposed to. i.e. make sure TT320 remote has good batteries and then make sure if it has other buttons on it like TV, cable, DVD etc that the correct one is pressed to control the TT320. My TV remote would not control my TV and by chance my kids had pressed the satellite button so I had to press the cable button and then the controller startedto control the TV again.
Nov 02, 2010 | TruTech TT320
How do I get from cable TV to DVD player
All you should have to do is press the dvd button on your remote to go to the dvd player. Then press the vcr button to go back to the cable tv, if it is hooked up the same way as mine. And you can tell if it is by putting in a vhf tape and you can start watching it play. Otherwise you will need to press the input button on your tv remote until you see the vcr or dvd main screen. from there press the dvd button on your remote for the dvd player or the vcr button for your vhf. After you are done with watching your movies and wish to go back to the cable or tv programs use the tv remote and press input until the shows come back on
Aug 16, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Disney Princess dvd player will NOT turn on or eject.
On front of television is the video, left and right audio plug ins. This is where you will plug the adapters from your dvd player. They are color coded for easy installation. Step2Make sure the adapter is also plugged in to back of dvd player. Step3Plug dvd player into power source and turn on. Step4On the front of television there is a tv/av button. Press this button twice or until it says video 2 in upper left hand corner of television. Step5Insert movie into dvd player and enjoy. To get your tv back to cable press tv/av button once.
Apr 20, 2008 | Disney Princess MCP DVD2050P DVD Player
I just rented a new dvd from Blockbuster and I get a parental screen that comes up. I can't get past it and can't watch the movie. All my other movies work fine. Even the feature dvd that came with the...
You have the rating set on your DVD player to lower than the rating of the movie you are trying to watch.
Somewhere in your setup menu of your DVD player (press the "setup" button on the remote with disc stopped or no disc) you will find a place to set the parental lock. Either turn it off, if that is an option, or set it to the rating of the movie (or higher) to enable viewing.
Feb 14, 2008 | Televison & Video
RCA DVD PLAYER RC5220P
My niece set the lock code and forgot it. How do I unlock it so i can watch my regular rated R movies
Nov 28, 2007 | RCA RC5220P DVD Player
Mitsubishi DD-6040 DVD Player Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
